Friday, Oct 14, 2005 at 23:34
Sorry Eric.. Being an Auto Electrician with over 22 years Experience and I am Highly Qualified at that..I have to disagree with you, 100%..I'm not trying to upset you and I know I can come across arrogant and that's not my intention...
Everything you say in your first post and your second post is absolutely wrong..and could be dangerous..
As an example, If what you say was true about wiring designed not to set the car on fire, How do you explain the Cable from the Battery to the Starter motor..A very heavy cable..The wire from the Alternator is 6mm or more..
According to you, this would not apply to "Code".
It's actually up to the deisgners and engineers to make sure that wiring does it's job..
I'm not sure by what you mean about "Code". If there were "Very Strict Codes" to wiring, every vehicle on the road would almost certainly fail..
How many Audio Systems are installed by unqualified personell and not installed correctly..?
To top it all off, the wiring in Automotive Applications just does it's job and that's that..I'm not even sure that Automotive Wiring has anything to do with the Roadworthy Certificate..Not that I know much about RWC's..
All Wiring that supplies power to anywhere in the vehicle should be adequately fused..That's what stops fires in the event of an accident or inadvertant shorts to ground..
Secondly, Any incandescent Bulb no matter what vehicle, Is the same as it was 40 or more years ago..I defy you or anyone that can tell me that Incandescent Bulbs that are used every time a vehicle is used, eg: Tail Lights, Headlights and indicators, Last the lifetime of the vehicle..They don't..Bulbs that are used rarely, eg: Reverse Lights etc. May last a long time...Dash illumination is run through resistance (For Dimming Purposes), so they do seem to last a long time, Maybe even the life of the vehicle..
Thirdly, I would rather have a heavy cable short to ground than a thin cable...If you know a little of what you're talking about, you'd know that a thin cable, say 3mm or 4mm shorted to ground has a much higher chance of setting something alight. Try shorting a 2ft length of battery cable and do the same with a 2ft piece of 3 or 4mm. Then post your results..
Fourthly, There should be no resistance whatsoever to any device on the vehicle, especially Light Bulbs..The only thing that has deliberate resistence is something that requires a voltage drop. Eg: Some Ignition Coils, Fan Motors (to control the motor speed), Some
Fuel injectors and Adjustable Resistance to Dash Illumination Bulbs..
I'm going to repeat myself again... There Should Be No Resistance and No Voltage Drop, Whatsoever, In Any Wiring Loom Unless It's Deliberate..The Only Deliberate Resistance In A Wiring Loom, That I know Of, Was In The Early Holdens, To Drop The Voltage To The Ignition Coil...
Headlights, Especially, Should Have No Resistance In The Wiring To Them At All..If You Add Higher Wattage Bulbs To The Headlights, Then Make Sure That You Fit A Relay To Supply Power To Them...The Wiring in a vehicle to orignal wattage bulbs is only adequate for the original wattage bulbs unless the manufacturer says otherwise..
Really, When it's all said and done, Automotive Wiring takes Common Sense..If you know what you're doing and you're confident you know what you're doing, then go ahead, but, Do Not Take Advice From People Who Don't KNow What They're Talking About...If you are not sure, Take it to someone who is Qualified and has a good reputation.....Otherwise you're asking for trouble...
Sorry Eric, I'm Afraid I Have To Say That You Got Quite A Lot To Learn When It Comes To Electricity..I Don't Mean that Nastily, Either..But, You Have Been Severely Misinformed Somewhere..
388715
