ARB LOCKERS
Submitted: Tuesday, Oct 04, 2005 at 10:58
robert4841
i recently had ARB diff locks installed in the front and rear of a jeep. dana 44 rear and dana 30 front. these were installed using the ARB compressor as per instructions. they work very
well however i find disengaging is very slow and makes turning in mud or dirt difficult for a short while. hopefully some users will respond as to the approximate time needed to disengage in their vehicles. engaging them is very easy and quick but disengaging is the problem. cheers, robert
Reply By: fozzy - Tuesday, Oct 04, 2005 at 11:20
robert
cple secs-no noticeale delay in
mine
when front is engaged it makes turning harder when doing u turn or 3 point turns etc but once disengaged no difference.
fozzy 100 td f/r arb lockers
132968
Reply By: Mudness - Tuesday, Oct 04, 2005 at 11:39
Hi Robert, if the axles are underload the lockers will not disengage. Sometimes you have to momentarily back off on the throttle and possible straighten the front
wheels (if you are turning hard on a fairly firm surface) to get them to unlock. You get used to them and they are great things.
132972
Reply By: Member - Gary W (VIC) - Tuesday, Oct 04, 2005 at 13:54
Ditto above. Ease off the load by straigtening or back off.
If they still don't disengage easily you might need to get them looked at.
I have front and rear air lockers and have had no trouble but a couple of mates have had some trouble and each time its been with installation. (Different issues to your tho)
Gaz
132988
Reply By: Member - DOZER- Tuesday, Oct 04, 2005 at 19:17
Almost instant disengagement on
mine.... make sure you are running thesame pressures front to back and thesame size tyres, and as above..take the strain off the driveline to allow them to disengage.
If nothing works, have a look at the solenoid exhaust ports...if there is mufflers on them, remove them.
Andrew
133029
Reply By: charlie - Wednesday, Oct 05, 2005 at 21:02
Have you asked on www.ausjeepoffroad.com? Since buying a jeep this year it has helped me no end. I got a lockrite put in the front of my wrangler and love it would have prefered the ARB but couldn't afford it yet.
Charlie
133179
