Myton's Gas Tank - (For Water Storage)
Submitted: Tuesday, Oct 04, 2005 at 18:07
BamBam
Does anyone know what a Myton Gas
Tank is?
In reply to my
Water Tank Q on 30 Sept one person reponded with get an old Stainless Steel Mytons gas
tank and use it ofr
water storage (about $10 -$20).
I wouldn't have the foggiest what one of these is or where I could get one?
HELP PLEASE!
Reply By: Rocky & Bullwinkle - Tuesday, Oct 04, 2005 at 19:25
Bam Bam,
The Myton tanks were popular in the late 80's and early 90's as LPG tanks for car conversions. They were in competition to the steel ones. Their claim to fame was their lighter weight.
Retesting them proved to be a hassle when they were 10 years old so most people got rid of them.
You might have some luck at an auto wreckers perhaps or try your local LPG auto converting business.
Rocky
133031
Reply By: DMECH - Tuesday, Oct 04, 2005 at 23:25
BAMBMAMIsugested the gas
tank option earlier ,would be ideal for
water tank original test pressure was 3.3 mpa ,if you under stand metrics , some said today thats about 1500 psi ,i think that should be enough to hold
water!! stainless right shape light easy to mount. check wreckers lpg instaling
places .i install gas and have 3 in various sizes laying around . saw afew in kelmscot w.a. at a gas place some months ago . still som running arround in cars even when the are out of date tanks ar good valves usualy fail. MYTON is the name of the manufactura
BEST LUCK dmech
133075
Follow Up By: Member - Phil [Sunshine Coast] - Wednesday, Oct 05, 2005 at 03:21
Hey Dmech, Howd ya get on with ya vehicle transport?
387311
Follow Up By: Member - Blue (VIC) - Wednesday, Oct 05, 2005 at 09:14
DMECH,
how do you go about cleaning them sufficiently for
drinking water or are they only for washing up? I have a 9kg bottle which I cut in half(long ways) to make a small BBQ. After a very exhaustive wash and steaming it out for about 5 houre(fringe benifit of work), it still stunk of LPG. In the interest of my own safety(considering the strong odour), I pumped a continuous flow of argon into it while I cut it to reduce the chance of it doing anything nasty. I have cooked on it several times and if you put your face close enough, you can still smell the LPG.
Blue
387322
Follow Up By: DMECH - Wednesday, Oct 05, 2005 at 23:53
phil i ended up using car transporters devision of toll ipec ,they trans .to ether melb. or
adelaide then put on train for rest of trip,can take up to 14 days. so can let you know about the train bit when ute arrives.cost 1256.oo incl gst[ pay up front] worked out cost of flying over /drive back but would be at least 1100.oo plu cnt aford the time either about 5 days allup. hope you have sorted your trns. out ihave no problems with rail bit. i can remember years ago when i used to have holdens ,you would get rear w/brg noise after about 60.000 ks which was apparently caused by the constant rocking of vehicle on train , brgs being in one spot ,not turning to reload with grease . ball running in race metal/metal contact.
regards dmech
387410
Follow Up By: DMECH - Thursday, Oct 06, 2005 at 00:02
blue . dont know about getting smell out of
tank most peaple that got tanks from use for washing only . these tanks are made of good quality s/steel they unlike steel may be impervious to gas , you might have to talk to a chemist, must be somthing to get rit of chemical agent that is used in the gas , this agent is put into the gas so that it can be smelt in the event of a leak cant remember what the chemical is , would have to look up books .
dmech
387411
Follow Up By: DMECH - Thursday, Oct 06, 2005 at 00:07
just a thought may be wash in hot caustic bath try eng recon place might be the go!
dmech
387414
Follow Up By: Member - Blue (VIC) - Thursday, Oct 06, 2005 at 00:14
I believe(but happy to stand corrected) that "Tert-dodecylmercaptan" is the chemical used to scent LPG. We use it at work but we don't have an antidote for the stench.
387415
