The Simpson, aussie super springs and other gear
Submitted: Thursday, Oct 06, 2005 at 06:27
ThreadID: 27020 Views:8850 Replies:4 FollowUps:8
Just returned from a Simpson Desert crossing with the Simpson Desert Bike Challenge. Great bunch of people doing a wonderful job to raise money for Paraplegics. Also an excellent way to do some 4WDing. We were carrying a lot of weightas we needed plenty of water for a pushbike rider, therefore also more gear as we took longer to get across staying with the bikes. This provided a real test of the Aussie Super springs TJM talked me into adding to the shackle spring set up on the rear of my 60 series cruiser instead of polyairs. They worked beautifully, handling the load, the corrugations and the dunes smoothly. Vehicle handling much improved as well. The drive was more comfortable than last years in a hired standard 100 series where clearly the vehicle was struggling with the weight.
I also have an auto lokka fitted at the front. This was a blessing on sand dunes where the looka was in use on twisting tracks and didn't need to be turned on and off at every bend.
Not sure whether I used the right tyres or not. Sumitomo MT Serangetti's. Just happened to have them so put them on rather than my new set of Kellys. Last year we had masses of mud and the outlook for weather this year was a bit dodgy. The Sumitomos, running at about 24psi in the desert, seemed fine. Can't find any evidence of chipped lugs from the gibber sections either.
Do it.
Reply By: Shane (QLD) - Thursday, Oct 06, 2005 at 10:57
mfewster,
I have a 60 series, how much are they fitted or just straight out to buy ?
AnswerID: 133261
Follow Up By: mfewster - Thursday, Oct 06, 2005 at 17:14
The springs cost $499.00 fittrd by TJM in Adelaide. They also raise the height a little. Ride is probably a bit firmer when unloaded, but rides flatter when cornering. Really comes into its own when the load increases. Worth looking at if you regularly carry extra weight, but if you only load up occasionally, might not be the best solution. It's hard to describe how the super spring works. It's not just another spring leaf. It joins rhe ends of the shackle together making the whole assembly look like a D with the curve of the D facing downwards. The top metal components slide over a poly bush as the shackle flexes.
FollowupID: 387510
Follow Up By: ACDC - Thursday, Oct 06, 2005 at 18:24
They are made in India for $20 and you paid how much!
FollowupID: 387518
Follow Up By: Member - David 0- Thursday, Oct 06, 2005 at 19:37
And a BMW 5 series is made for $5000 in South Africa.....so?????
FollowupID: 387528
Follow Up By: Eric from Cape York Connections - Friday, Oct 07, 2005 at 06:22
A bmw for 5000 wonder what the float would cost.
Might get one for xmas for the boss.
LOL
all the best
Eric
FollowupID: 387622
Follow Up By: Member - David 0- Friday, Oct 07, 2005 at 07:51
Hey Eric,
We could build a reed raft
David
FollowupID: 387628
Reply By: mfewster - Thursday, Oct 06, 2005 at 23:35
Hello ACDC
Now I really am curious. I might be wrong, but I thought they were made in Australia. Check their website. Even so, what evidence do you have for your statement as to the source and cost of the item? Or is this just another anti asian bash? I have seen several postings from people who make statements like this on this site (I am certainly not blaming the site, but I am intrigued by a few of the lurkers who seem to make statements like this and then disappear into the ether) And if you are correct, where would you suggest I went about sourcing them from, at your suggested price?
AnswerID: 133371
Follow Up By: ACDC - Friday, Oct 07, 2005 at 21:30
I import several products from China and Taiwan they are great people to deal with, always friendly. businesses in Australia could learn a lot from them, they will actually listen to you and produce what you want.
As for where Supersprings are made i would be very surprised if they were made here.
FollowupID: 387738
Reply By: Shane (QLD) - Friday, Oct 07, 2005 at 06:28
Any reason why they recommended the springs over the Polyairs, as they would be about the same price fitted. I imagine the advantage of the Polyairs is that they can be pumped up either side to equalise the load as such, while maintaining a normal ride when the vehicle is empty.
AnswerID: 133381
Follow Up By: mfewster - Friday, Oct 07, 2005 at 06:45
G'day Shane
I think you are right about the plus sides of the polyairs. They told me the A. Springs effect adjusted itself according to the load. ie, no pumping adjustment required. They are certainly a little firmer when empty, but not enough to bother me and as I regularly carry a load plus extra weight from an extended range fuel tank, they suit me fine. Cornering control, empty or full, is much improved.
FollowupID: 387623
Follow Up By: Shane (QLD) - Friday, Oct 07, 2005 at 21:48
mfewster,
Yeh ! know what you mean in regard to cornering, I fitted a Dual battery system the other day & with the Missus on the left side I'm sure it's down to buggery on the left when your driving & also going around a r/h corner. (And it's got a 2" lift). I also have a current model CRDi Terracan & the thing is like greased lightning in regard to pickup & cornering, makes the Cruiser ( it's Turbo) feel like a Dinosour, but I know which one I'd prefer for scrub bashing.
FollowupID: 387746
Reply By: mfewster - Sunday, Oct 09, 2005 at 10:53
G'day evryone
Just found a site from the super springs maker which might be useful to anyone interested in how they work
http://www.aussiesupersprings.com.au/
AnswerID: 133746
