GQ needs new suspension bushes. Rubber or neoprene?
Submitted: Saturday, Oct 15, 2005 at 20:40
ThreadID: 27291 Views:6716 Replies:6 FollowUps:15
Any luminaries out there who can give some advice on which way to go with fitting new suspension bushes?
I favour rubber bushes but am open to other comments. Have had a look at the Neoprene and they 'look' OK but I worry that they will settle in too hard and give the truck a harder ride.
Reply By: warthog - Saturday, Oct 15, 2005 at 20:51
I would hate to venture an opinion as a luminary, so I will have to give someone elses opinion and mention that I have been told neoprene does not flex as well as rubber and may limit your suspension articulation. If that matters to you.
AnswerID: 134756
Follow Up By: Leroy - Saturday, Oct 15, 2005 at 20:56
I think genuine nissan rubber is the go. Seen noeprene bushes spit after 9 months plus they gave my vehicle a harsher ride.
Leroy
FollowupID: 388768
Follow Up By: Willem - Saturday, Oct 15, 2005 at 21:06
Thanks Warthog Yes suspension articulation does matter to me.
Thanks for the advice Leroy
FollowupID: 388770
Follow Up By: cokeaddict - Sunday, Oct 16, 2005 at 13:29
Hye Willem,
I agree with Leroy here, Definately Genuine Nissan ones for that job mate.
Ange
FollowupID: 388811
Reply By: 120scruiser - Saturday, Oct 15, 2005 at 22:33
Now that I have found and used my dictionary I can say that my neoprene bush's lasted 3 weeks before I put genuine toyota rubber ones back in.
AnswerID: 134763
Follow Up By: Willem - Sunday, Oct 16, 2005 at 08:31
Thanks for your feedback, mate
FollowupID: 388794
Reply By: Martyn (WA) - Saturday, Oct 15, 2005 at 23:52
Willem,
As others have mentioned rubber is the go, nolathane and other similars are harder, slightly less articulation, harder ride (road holding wise). I've used the nolathane bushes on the steering with great success, but not on the suspension. Cheaper as well, to boot.
Keep the shiny side up
AnswerID: 134764
Follow Up By: Willem - Sunday, Oct 16, 2005 at 08:30
Thanks Martyn
You have convinced me
FollowupID: 388793
Follow Up By: Member - Chrispy (NSW) - Friday, Oct 21, 2005 at 09:25
Spot-on Martyn.
I've gone back to rubber in the suspension areas - urethane was too harsh, wore quickly because of mud/sand grit and felt "old" a month after installation. Expensive lesson......
FollowupID: 389451
Reply By: signman - Monday, Oct 17, 2005 at 14:41
Why not bronze greaseables???? Last forever (with service) and minimum wind up.
AnswerID: 134928
Follow Up By: Willem - Wednesday, Oct 19, 2005 at 14:58
Dunno Didn't think that they made them for Nissan radius arms
FollowupID: 389194
Reply By: Bros 1 - Wednesday, Oct 19, 2005 at 11:09
Willem,
Probably a little late with my opinion as you may have already chosen, but for what it is worth, here it is.
Four years ago i was going up to the Cape and other places up that way. After hearing about the roads i decided to upgrade the Tojo suspension.
1,600 oxford scholars later i had 8 leaves allround, greasable neoprene bushes on all hangers, new air shocks, new steering damper. I cracked an engine mount off the chassis rail at the top, got it welded and still there. Whether this was due to the stiffened suspension or the roads was anyones guess.
Since then i have been to Bathurst Bay twice and done the Qld outback once.
The neoprene bushes seem to give a harder ride when the ute is empty, but when loaded there is no difference. The old Tojo will be 20 next month. She is my only vehicle so gets used for everything.
Every service (5000) just hit them with the grease gun on the way round.
Does this posting make me a luminary as described in my Collins Gem.
Yours sincerely
Bros
Work is the curse of the down and out bludger.
AnswerID: 135204
Follow Up By: Willem - Wednesday, Oct 19, 2005 at 14:55
Thanks Bros....I do think that you fit in to the luminary category lol
FollowupID: 389192
Reply By: Member - Crazie (VIC) - Wednesday, Oct 19, 2005 at 12:05
How about Polyurethane.....as Neoprene is like wet suit material, wont do the GQ any good at all. lol sorry mate. Polyurethane is easier to get too.
but i am still searching
AnswerID: 135209
Follow Up By: Truckster (Vic) - Wednesday, Oct 19, 2005 at 12:27
wetsuit maybe easier to get in the desert....
Go with genuine, they last longer
FollowupID: 389154
Follow Up By: Willem - Wednesday, Oct 19, 2005 at 14:57
Trucky
Priced genuine today =$500 for 16 bushes....ouch!
FollowupID: 389193
Follow Up By: Truckster (Vic) - Friday, Oct 21, 2005 at 00:07
which actual bushes are you replacing? Everything by the sound of it..
FollowupID: 389425
Follow Up By: Willem - Friday, Oct 21, 2005 at 09:19
All the front and rear radius arm bushes, both sides
Nissan told me there were 8 bushes to a side. I counted 5. Maybe there are others in the kit.
FollowupID: 389450
Follow Up By: Truckster (Vic) - Friday, Oct 21, 2005 at 09:33
Take lots of KY with u.
is it 2 per end of each radius arm? thats 8, but not $500 worth. Lemme know if you want me to get prices from my bloke.
FollowupID: 389452
Follow Up By: Member - Crazie (VIC) - Friday, Oct 21, 2005 at 09:37
Hey Willie
best i got was $436 plus gst, so bugger all better. that was for
front radius arm bushes to diff mount x 4
front radius arm bushes to chassis mount x 4
front panhard rob bushes x 2
rear trailing arm bushes upper and lower x 8
rear pandhard rod bushes x 2
All gen nissan rubber
ads
FollowupID: 389453
Follow Up By: Willem - Friday, Oct 21, 2005 at 09:42
Ads, Thanks for that. Lets see what Trucky comes up with
Yes please Trucky. Am always interested to get the best price.
Going offline now. Will be on again tonight
FollowupID: 389458
