Gearing up with 33"s
Submitted: Sunday, Oct 16, 2005 at 21:42
ThreadID: 27317 Views:2152 Replies:4 FollowUps:0
Hi, if I go up from 32x11.5x15's to 33x12.5x15, will it make a significant difference to my gearing?
Anything will help, but what sort of change in revs can I expect if I'm currently doing 2,300rpm @ 110km/h?
Reply By: Rock Crawler - Sunday, Oct 16, 2005 at 22:33
Will make a slight diffrence , but nothing you would worry about
AnswerID: 134854
Reply By: fisho64 - Sunday, Oct 16, 2005 at 23:20
measure the circumfurence of each tire and use this formula
(circumfirence of 32" tire) divided by (circ of 33" tire) times 2300
this will tell you the RPM at 110 kph
AnswerID: 134858
Reply By: Sarg - Monday, Oct 17, 2005 at 12:29
Try putting some numbers in this
http://www.osella.com.au/gear-ratios.htm
AnswerID: 134906
Reply By: TroopyTracker - Monday, Oct 17, 2005 at 17:06
V8,
I think you'll probably find they'll "tram line" a bit more which can get annoying. I recently went from 35x12.5's to the 33x12.5 and had hoped this feeling would go away but nope, so figured it has to be because of the width. Did wheel alignment still no change. Tyre bloke told me should have gone for the 32x11.5's. Don't understand how that 1 inch can make all the difference but hey,
Matt
AnswerID: 134945
