Monday, Oct 17, 2005 at 17:22
The vehicle was measured with full
fuel tanks, and nothing else inside other than what's supposed to be there. The standard bullbar is the lightweight aluminium variety.
Here is the text of the email I sent to King Springs;
Gordon [mailto:pgor9658@bigpond.net.au]
Sent: Monday, 17 October 2005 11:16 AM
To: sales@kingsprings.com.au
Subject: GU III Spring Height
I have just purchased and installed set of KDFR-42HD and KDPR-58LP springs, along with the appropriate Koni shocks, as per your recommendation.
The front of the vehicle has been lifted 56mm on the front left, 60mm on the front right, 33mm on the rear left, and 38mm on the rear right. All measurements were made from under the lip on top of the alloy rim to the bottom of the wheel arch flare, both before and after installation.
My question is, does the lift under the front end seem normal with this type of spring, or is it possible they were not installed correctly, or are these springs designed for vehicles that have a winch, thus the extra lift?
Thanks for your advice.
388933
