new exhaust
Submitted: Thursday, Oct 20, 2005 at 17:30
GOB & denny vic member
evening people
looking at having the exhaust done in the next few weeeks and just wondering which part comig off the turbo is the "dump"looking at the manual there is a bend but that is all it shows
i am looking at a 3" system but want to make sure its done properly as the best quote so far is $550 worst was $1200
steve
Reply By: Nudenut - Thursday, Oct 20, 2005 at 20:34
550 for tube steel
1200 for stainless?
135472
Follow Up By: GOB & denny vic member - Thursday, Oct 20, 2005 at 20:42
goodday nudie
not sure but i dont recall any mention of stainless
will have to get the quote out again and check
steve
389392
Reply By: Truckster (Vic) - Thursday, Oct 20, 2005 at 21:52
go 3inch dumppipe right to the end... thats the bit out of the turbo itself.
or go twin stacks and 239048230498 clearance lights to be one of the wannabe truckies :P
But
yea apparently the larger dumppipe makes a difference
135485
Reply By: Member - John - Thursday, Oct 20, 2005 at 21:53
GOB, the dump pipe ia a cast piece right at the bottom of the turbo hosing. The factory one knecks down to 2 1/8" or there abouts. You will need a new one.
135486
Reply By: warthog - Thursday, Oct 20, 2005 at 23:15
See if you can get a threaded collar welded on up near the dump pipe so you can fit a pyro (exhaust temp guage) before the exhaust is fitted. Easier and cheaper than once the exhaust is in place.
135504
Reply By: Member - JohnR (Vic)&Moses - Friday, Oct 21, 2005 at 07:59
Steve, what is the range of systems from, what is there quality like, and do all the pipes have mufflers? Of course hearing the non muffled one is like music, nice and gruffff. LOL Perhaps I should call you.
Going to Jeffs Shed this weekend? Hope to be there on Saturday afternoon........
135518
Follow Up By: GOB & denny vic member - Friday, Oct 21, 2005 at 19:57
goodday again john
we will be going to the 4b show in the pm have to work till 3pm dash home quick showeer and back to 4b show will go and havea meal later across the road probably be there about 5pm
steve
389538
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Oct 21, 2005 at 20:46
I have a committment in
Ballarat during the morning and not sure what time we will get there Steve. Have your number and you have
mine - with the rig pic anyway.
cheers mate
389545
Reply By: GeeVee - Friday, Oct 21, 2005 at 11:00
Steve,
I had the exhaust on my 4.2L GQ (Turbo) replaced about 6 years ago. Work done by a local mufler
shop, who suggested a very good design modification. He welded a bracket on the exhaust pipe in line with the bottom of the block and used a threaded stud hole in the bottom of the block to secure the lower section of the exhaust pipe. No stress or strain transmitted back to manifold or turbo. After the first bend he welded a 150mm flexible section, to which the balance of the exhaust system was fitted. The GQ's "shudder" when turned off, and the aim was to have the flexible section absorb the differential movement between body and engine when switched off. Six years down the track still solid as a rock. Cost $475 at the time.
Regards,
135552
