Milford Cargo Barrier
Submitted: Thursday, Oct 20, 2005 at 19:56
Member - Crazie (VIC)
Hey Kids
Have just purchased a milford cargo barrier off a very nice gent on the overlander/jackaroo
forum. Came with all the mounting gear. Things to remember when buying one,
1. will your draw system fit in and not interfere with the barrier - yes thankfully
2. Will the fridge slide and "Fire and ICE" still fit in with the barrier - let you know tomorrow hahaha, but i think so
3. Do the seats back into correct position and can you un-latch them to fold the forward - yes.
So i have had a very successful installation. I didnt use all the mounting gear. Put the top mount into the rear handle with a stronger bolt, and down the bottom i cut out one little bar on each side and made a new bracket that wraps around the barrier and bolts down into an exsisting bolt hole.
Took less than 30 mins including making the brackets and cutting down the milford ones for the top.
love it when things work out.
Ads
Reply By: porlsprado - Thursday, Oct 20, 2005 at 22:17
What do you mean "put the topmount into the rear handle" like i don't have barrier and am keen to get one so do you mean you literally bolted it through the rear handle which doesn't sound right or it looped around the top rear handle ? sorry, just can't picture it, and on that subject, can you load a picture maybe ? What did you cut the milford with - hacksaw, plasma cutter (joking, just interested in the finer details), thanks.
135490
Follow Up By: Member - 'Lucy' - Thursday, Oct 20, 2005 at 22:49
Mate! I've seen this dude in action.
Everything is done with an airtool of some kind.
In this case I am guessing that he used an air chisel ( Maybe a jack hammer), and definitely air spanners that tighten up so fast that they strip threads leaving you contemplating WTF happened there.
And as for his 'special fastening device - superglue is his fetish/strength.
389412
Follow Up By: Member - Crazie (VIC) - Thursday, Oct 20, 2005 at 23:37
Dear Lucy
It is my pleasure to work on your car on weekends, an yes the was one bolt that i stripped with the rattle gun, which was quicly rectified, so nah nah na nah na
ps. how did the fire go in the over head consol...... hahahaha
Dear Porlsprado
I used the exsisting hand rail in the rear and mounted the metal bracket behind it and the rear bottom one, i made a new bracket
!MPG:18!
!MPG:17!
389416
Follow Up By: Member - 'Lucy' - Friday, Oct 21, 2005 at 10:55
Ooooooooooooooo! I luv it when talk like that. (LOL)
Even though Crazie loves his airtools I have to admit that he has a very inventive, flexible mindset when it comes to mods on 4WD's.
Also, as he reminded me, a very helpful individual as a number of
forum members, including myself, can attest to.
I have forgiven, but not forgotten that rattle gun stripping incident, and I do like your work on the Barrier mod, however I would have thought you could have painted it before posting a pic of it. (ROFLMAO)
389470
Follow Up By: Truckster (Vic) - Friday, Oct 21, 2005 at 11:01
did anyone else get a technochubby then?
389471
Follow Up By: Member - Crazie (VIC) - Friday, Oct 21, 2005 at 13:28
its mainly dust you clown
389492
Follow Up By: Member - 'Lucy' - Friday, Oct 21, 2005 at 15:21
The only dust 'floating around' that pic is good old fashion
B U L L D U S T.
389507
Reply By: pizzle - Friday, Oct 21, 2005 at 14:32
crazie
i've got a 97 jack just bought a cargo barrier out of a 2000 model thinking they were the same. the bloke i got it off couldnt remember how it went in. he gave my all the fittings he had. it doesnt seem to match up to any existing holes,is this the reason for your mods
appreciate any feedback,thanks
135589
Follow Up By: Member - Crazie (VIC) - Saturday, Oct 22, 2005 at 00:55
Hi Pizzle,
I modified the brackets cause i have a draw system in and the bottom mounts with the long lenghts of metal are meant to be bolt to where i have my draws bolted down. The Top mounts are meant to have 3 holes drill on each side, the centre hole being big enough to fit the metal plate in the sim above the window. I didn't was to drill, so used the hole where the handle is.
Although this is not the proper way to do it. It suits me.
ads
389593
Reply By: pizzle - Tuesday, Nov 01, 2005 at 20:10
crazie
can you give me a run down of your
suspension and tyre choice please,looks good
137334
Follow Up By: Member - Crazie (VIC) - Tuesday, Nov 01, 2005 at 20:35
Hi Pizzle
I have Ironman
suspension and Run Cooper St's 265/75/16. Yeh It works
well for the jack.Fully loaded I maintain a 50lift in the rear and about 40mm in front.
Ads
391033
