Cavilear Camper trailer water tank
Submitted: Saturday, Oct 22, 2005 at 14:02
ThreadID: 27462 Views:9260 Replies:5 FollowUps:1
Ive just bought a ten year old Cavilear Camper and I'm in the process of rebuilding her. Has anyone had any experiences with the heavy duty green 65lt water tank which the manufacter claims can be mounted underneath the trailer?. The Cavilear web sits shows a tank with a 4X4 parked on it to demostraight the strenght. I'm a bit concerned about hanging it underneath, with flying stones and the possibllity of bottoming it out. However it will save a bit of room inside the trailer having it underneath. Experiences good and bad welcome.
Reply By: Member - JD - Saturday, Oct 22, 2005 at 14:15
Hi pHIL123,
Mount it underneath just put a stone guard under it,Me personally I would find the trailers balance piont and mount it on the centre line of that point..with the strenght you mentioned in the add and the stone guard you should'nt have any problems..remember space is everything for a trailer.Just my opinion.
All The Best In Health And Wealth
JD
AnswerID: 135736
Reply By: Martyn (WA) - Saturday, Oct 22, 2005 at 14:29
JD,
Mines underneath with a stone guard around the outside, I've not had any problems at all. After a trip it's worth while checking to see if any stones have found there way between the stone guard and the water tank. Over time these little stones can vibrate themselves through the plastic tank. When I first took my stone guard off i was quite surprised how far some of these little stones had actually worn into the plastic.
Keep the shiny side up
AnswerID: 135739
Follow Up By: Member - JD - Saturday, Oct 22, 2005 at 15:26
Hi Martyn ( WA),
A little maintanance go's a long way..so true..better 40 minutes in the garage than hours on the track.
JD
FollowupID: 389631
Reply By: Member - Phil G (SA) - Saturday, Oct 22, 2005 at 14:53
I'm guessing the tank you're talking about is the one made by camel group:
camel water tank
Its not you're average caravan tank. The plastic is about a centimeter thick, and it has its own mounting system. whick obviates the need for straps, and probably the stone guard. I think they cost about the $200 mark.
I've got a Goughs undertray 80 litre water tank that has a similar rugged construction but costs over $500. I had to change all the hoses to taint-free Nylex water hose to stop the plastic taste.
AnswerID: 135741
Reply By: mfewster - Saturday, Oct 22, 2005 at 19:47
Re stones and stone guards around water tanks. I had a similar problem on a Cape York trailer with little stones and lots of dust/mud wedging between the metal guard and the tank . Didn't like the look of it and possible wear or rust issues. Cleaned it all out, then got a can of expanding foam and sprayed it into the spaces. No problems since.
AnswerID: 135756
Reply By: maroni - Saturday, Oct 22, 2005 at 21:37
hi there we have a cavalier camper with the grren water tank mounted underneath
travelled the gibb river last year no prob and travlled this year over east not a problem at all.
AnswerID: 135769
