water tanks
Submitted: Thursday, Oct 27, 2005 at 11:38
ThreadID: 27600 Views:2442 Replies:4 FollowUps:0
Hi all,
I have two water tanks on my caravan,both polythene plastic. After 10 years they now taint the water with an algea smell.I have flushed many times and added Tank Fresh compounds and added cup of bleach and filled and flushed after two weeks--- water still taints .I always filter water when filling.
Can anyone help??
Reply By: scoof - Thursday, Oct 27, 2005 at 11:52
I have heard of the same problem being solved by fitting new hoses to and from the water tank. The tank may be ok but the hoses have broken down!!!!!
This did work for a friend on a camper trailer water tank.
Regards Scoof
AnswerID: 136613
Reply By: Member - Beatit (QLD) - Thursday, Oct 27, 2005 at 12:00
Also do you drain water when returning from camping? And is the van parked in the sun, more importantly any of the water componants? Had a clear water filler hose do the same thing because it sat in the sun - replaced it with black and all was OK.
Kind regards
AnswerID: 136615
Reply By: flappa - Thursday, Oct 27, 2005 at 12:30
How do you fill it ?
My guess would be the gold ole Garden Hose.
Thats not a good start.
Give the Tanks a REALLY good flush out with BiCarb or Baby Bottle Cleaner. For REALLY bad , I've been told a diluted mix of Clorine (pool cleaner) works wonders.
Check all your hoses and change to food grade ones , and then , fill tanks using another food grade hose.
Shouldn't thereafter have a problem.
AnswerID: 136623
Reply By: Member - Doug E (NSW) - Saturday, Oct 29, 2005 at 15:46
Thanks to all members for your suggestions ,all will be applied and I am confident you are all on the right track.
AnswerID: 136922
