self inflating matress
Submitted: Wednesday, Jan 01, 2003 at 01:00
Dazza
how long does it take to deflate and roll up a 100mm matress and are they very durable.
Thanks for any info.
Reply By: rojac - Wednesday, Jan 01, 2003 at 01:00
depends how heavy you are and yes they are durable and comfortable.
Rob
10388
Reply By: Member - Terry- Wednesday, Jan 01, 2003 at 01:00
Dazza, allow aprroximately 2 minutes per matress.You get a better roll up if you roll once,unravel leaving the plugs closed,then roll up again with the plugs open.On longer camps we use the 100mm for sheer comfort and 50mm for overnighters.Dont be fooled by the original size when first seen at the store,they are rolled by machine.You will not roll them as tight,have a look at the bag the matress is supplied with.
10389
Reply By: Truckster - Wednesday, Jan 01, 2003 at 01:00
The pump I use to pump up is also a vacuum so takes no time.
otherwise queen size takes a while.....
10392
Follow Up By: Mick - Wednesday, Jan 01, 2003 at 01:00
Don't need a pump to inflae a self inflating mattress though so don't rush out and buy one!!
5451
Follow Up By: Truckster - Wednesday, Jan 01, 2003 at 01:00
I meant the pump for the inflatable boat, and the air matress for in the river...
I read it after I posted it then realized how it looked.. hey it was early in the morning ;P
5454
Reply By: chopper - Wednesday, Jan 01, 2003 at 01:00
Good advice above about rolling twice. We use a 100mm one when base
camping or sleeping in the truck or 2x25mm ones when walking.
The 100mm is very comfortable.
Two people roll and bag it in about two minutes.
10395
Reply By: Mick - Wednesday, Jan 01, 2003 at 01:00
Dazza, Roll slowly and use your knees to keep it rolled. Two minutes tops. Very comfortable and even if the plugs aren't done up or a leak develops they are OK.
10400
Reply By: Member - Greg - Wednesday, Jan 01, 2003 at 01:00
Hi All,
Re self inflating matressesssss,what brands does anyone recomend,I have looked at the thermarest ones,very xe and I didn't see at 100mm one.I am a fairly big guy and hate my hips digging into the ground.
regards Greg G
10404
Follow Up By: Member - Melissa - Wednesday, Jan 01, 2003 at 01:00
Hi Greg,
Hubby and I used the thermarests for nearly 10 years until going into a campertrailer. Yep, they are expensive but in 10 years we never had a problem and still use them regularly for overnight visitors etc. Friends with cheaper versions have had to replace theirs after nowhere near the use we got from our thermarests. Don't think you can get a 100mm one though. At least, not when we bought ours.
A couple of tips...the longer they mattresses have been stored, the longer they seem to take to self-inflate when next used. We usually roll ours out, open the valve and by the time we made up our bed and got the rest of our gear sorted, just closed the valve. Also, close the valve as soon as you finish rolling them up and before putting them in the bag. Stops them from inflating whilst you're trying to get them in the bag. Very annoying...
Hope this helps.
:o) Melissa
5453
Follow Up By: Member - Nigel - Wednesday, Jan 01, 2003 at 01:00
We got one from a Great Outdoors
camping shop. Make sure the foam is glued to the outer. Best no to store them rolled, only roll them for travel and that way they will maintain their comfort. They are dear but are also more comfortable than a 100mm standard foam matress, so in my opinion they are worth the money.
5463
Follow Up By: Lyds - Thursday, Jan 02, 2003 at 01:00
I too have Great Outdoors. Get the blue ones with the 2 valves (rolls better for easier packing) and they also have generous carry bags.
We have also made covers for the matteresses; improves insulation and reduces sleeping bag sliding around.
cheers,
Stuart
5477
Reply By: Phil G - Friday, Jan 03, 2003 at 01:00
We've used one of the double 100mm self-inflating since they came out a couple of years ago. Very comfortable. "Self-inflating" ???
Well its basically a high density foam mattress with a plastic cover. We leave the bungs open all the time. Ours has "felt" on one side to stop the sleeping bag going for a slide.
Downside is the bulk. Rolled up, its bigger than a double swag and its hard to find somewhere to store it. We wedge ours between the rear pillars against the cargo barrier. And rolling up is best done by two people and I couldn't be bothered trying to get it tight - once I've rolled it I put two webbing straps around it and pull them tight.
10487
Reply By: Phil P - Saturday, Jan 04, 2003 at 01:00
You may want to consider a portable stretcher bed, Marlows have them on sale in
Melbourne (Preston Store) for $49.95. When folded they are smaller than the 100mm matresses.
10557
Reply By: Bob Y. - Saturday, Jan 04, 2003 at 01:00
Dazza, Going on from Phil P's post, back in the mid '70's when I was working on a station on Barkly Tableland during the BTEC Scheme, all the stock inspectors used to use a fold up bed/mattress, that folded into something the size of a medium to large siutcase. They'd just roll their swag out on it, it was comfortable and they were off the ground. The Long Haired Plague Rats were bad at the time, which meant most reptiles were living on a high protein diet, and their size indicated this. Getting back to the folding beds, being 4" off the ground meant the small snakes could go under the bed, but the larger King Browns had to go around.
As
young blokes we never used to worry about sleeping on the ground, probably because we were too tired most evenings. However, in 3 years there, only saw one very large King Brown get in a blokes swag, but that's another story....
On s/inflating mattresses, chopper pilot had one, only 3/4 length, and about 11/2 - 2" thick, he reckoned it made for a good nights sleep. Catch you later...
10568
Reply By: CJ - Wednesday, Jan 08, 2003 at 22:09
We have a Great Outdoors mattress, "double bed size", one of the best pieces of
camp gear I have bought. Tried stretchers, air beds, etc. over a 30 year period, but these are great.
Mine has 4 'plugs' and takes 2 people a couple of minutes to roll up - although I have done it by myself. We try to wipe it with a damp cloth while rolling to keet any 'grit' from sticking to surface - saves on wear? Storage (Subaru) IS a problem but it is worth it for the comfy close sleep - just fits across the car.
10866
