79 series turbo radiator into 75 series.
Submitted: Wednesday, Nov 02, 2005 at 19:53
ThreadID: 27762 Views:2324 Replies:2 FollowUps:1
Giday,
Can anyone tell me if the new 78/79 series turbo radiator fitted to the 122kw motor will fit straight into a 75 series troopcarrier. I believe it is longer, so I hope you would only have to space the bash plate down.
Reply By: lost - Wednesday, Nov 02, 2005 at 20:50
you'd be better off just buying a aftermarket radiator and fitting that. id expect a aftermarket jobie would be a better cooling system then the toyota ones.go a 3 or 5 core, as the toyota radiators are only 2 core.
AnswerID: 137505
Follow Up By: Troopie - Thursday, Nov 03, 2005 at 12:57
In an emergency I tried to see if a 75s rediator would fit in my 78s (naturallury aspirated).
Wouldn't fit - mounting points and size of radiator were different.
FollowupID: 391271
Reply By: bogger - Friday, Nov 04, 2005 at 07:50
Thanks guys,
Have taken advice and have ordered a desert cooler radiator.
Have a good one.
AnswerID: 137716
