Fuel Problems - 60 series cruiser
Submitted: Saturday, Nov 05, 2005 at 01:39
Legend_171
On the 60 series cruisers, do you have to replace (or remove & clean) the filter that is attached to the chassis rail on the drivers side. The one you check to drain
water.
Reason for asking is - Have recently (8,000k) had injectors replaced and pump rebuilt - is that at times the motor misses as if there was air in an injector.
The last time it happened the car actually seemed to run out of
fuel (had over 100ltrs) but it was as if I had run out of
fuel as I had to use the primer to be able to restart the car.
Any ideas, Thanks in advance.
Chappie
Reply By: G-wizz - Saturday, Nov 05, 2005 at 02:25
Don't have a
fuel filter attached to the chassis rail on my HJ61 and so far I haven't had to replace the one on the drivers side of the engine block.
137885
Follow Up By: keny - Saturday, Nov 05, 2005 at 13:11
hi is this a 2h motor if so the
fuel bleed pipe back from injectors runs behind pump to suction side of lift it has a clip around it and it the clip wears a hole allowing ingress of air making the engine stop intermittently have done at least ten very hard to find first time out have done at least ten or twelve with same problem hope this helps regards kenny ( have a good life)
391545
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Nov 05, 2005 at 05:06
Its getting air in somwhere. I had a simular problem with a lister generator except t had a glass bowl on the
fuel filter and ou could see the air mouinting until it started to run rough and cut out. I super tightened all the unions (couldnt get spare o rings etc) and that solved it
137888
Reply By: Peter 2 - Saturday, Nov 05, 2005 at 07:25
The sedimenter (the black tin on the chassis rail) that has a couple of wires coming out of it is the
water trap which brings the
fuel filter light up on the dash when the
water gets in it.
They do rust out due to not being cleaned out regularly.
Is there any dampness or smelll of diesel around it?
There is also two ten mm headed bolts on it one at the bottom (the drain) and one up on the top off to one side (breather). Both of these should have a fibre washer on themto stop air leaks.
I'd reckon it has a pinhole in it and is sucking air or there is an air leak somewhere in the
fuel system.
I've repaired a few by soldering the holes up but you can usually pick up a decent one at the wreckers.
137891
Reply By: Legend_171 - Saturday, Nov 05, 2005 at 09:35
Thanks for your responses, I now know
where to start looking. I was suspecting an air leak somewhere. I have no idea as to where it may be as there is no
sign of any leak, dampness or dust being attracted to anything/anywhere.
My other thought is that the
fuel line is nearly blocked somewhere. I have replaced the
fuel filter that is on the side of the motor and has no effect.
But, when I used to drain the
water trap
fuel ran out freely (from memory) and recently the flow seems to be restricted. I may have to pull my
fuel lines out and check they are clean.
137899
Follow Up By: Member - Pesty (SA) - Saturday, Nov 05, 2005 at 11:54
Jump a hose across and bypass the
water trap and see if that helps,
mine was disconected when i bought it, rusted out with many holes.
I have never had any problems in 200,000 as i run
water dispersant /injector cleaner through regularly and change
fuel filter often.
I intend to fit glass based filter/watertrap unit at some stage which will negate need for such a unit.
Cheers Pesty
391539
Follow Up By: keny - Saturday, Nov 05, 2005 at 13:34
im sure this pipe is your problem if the filters were blocked you would be very short of power
391549
Follow Up By: keny - Saturday, Nov 05, 2005 at 15:32
i did another one for a mate today as usual there was no evidence of moisture at the leak site
391560
Reply By: Legend_171 - Sunday, Nov 06, 2005 at 16:34
Thanks to all, I will be checking the sedimenter and the
fuel return for problems.
The problem is intermittent - or so it seems. It may only be that is is running OK untill it collects enough air to cause the problem.
Thanks for your help. See you on the track - somewhere - sometime
138066
Follow Up By: Legend_171 - Sunday, Nov 06, 2005 at 16:42
Sorry, It is a 2H motor
391714
