Suspension upgrade for New Hilux
Submitted: Sunday, Nov 06, 2005 at 13:40
sheps
Having just bought a new Hilux 4x4 diesel, I am advised that after fitting a long range
fuel tank,
water tank & storage drawers with recovery gear etc, I will require a rear
suspension upgrade. Has anyone had experiense with the 'coil in spring' systems by Outback
Suspension in Clayton VIC? At $700 fitted it appears reasonable value.
Reply By: Michael_FNQ - Sunday, Nov 06, 2005 at 15:03
Yes the coil upgrade works but it is far better just to fit a leaf spring that is designed to carry the weight. You will end up with a much better ride is you replace the back springs with a good aftermarket spring.
138055
Follow Up By: troy - Sunday, Nov 06, 2005 at 16:48
would that setup work in the front and rear leaf sprung hilux?
Troy
391716
