CT access into the Wonnongatta Valley
Submitted: Monday, Nov 07, 2005 at 12:42
ThreadID: 27898 Views:5280 Replies:4 FollowUps:11
Looking for the easiest way into [and out] of the Wonnongatta Valley. I'll be towing a CT behind a TD Auto Prado 120. Would like to go in from NE Vic if this is possible, but will take the easiest route for the campers [and SWMBO] sake! Any map references and further info would also be appreciated.
Cheers!!
Reply By: Well 55 - Monday, Nov 07, 2005 at 13:03
T/O in Myrtleford and take the road past Buffalo Dam to Dandongadale, go S/O and take the Buffalo West Branch to the Gatta. Ok tracks if its dry.
Return the over the same tracks.
AnswerID: 138244
Follow Up By: Inland Sailor - Monday, Nov 07, 2005 at 13:51
THanks for that.
I'm also wanting to know how easy is it to take the CT into the Wonnongatta? Is it OK to do or not recommended?
FollowupID: 391902
Follow Up By: Well 55 - Monday, Nov 07, 2005 at 13:55
No, its ok providing the tracks are on the dry side.
FollowupID: 391905
Follow Up By: geocacher (djcache) - Tuesday, Nov 08, 2005 at 00:14
Don't take the West Buffalo track. Take the East Buffalo Track. It's far easier than towing a camper up Harry Sheppards.
The east will take you in to the Helipad at the top of Van Dammes Track and it's an easy run down into the Wonnangatta from there.
Followed a mate and his T-van in there a while back and will go in this way on Friday night in the dark.
I've probably got a plot file somewhere if you want it.
Dave
FollowupID: 391995
Follow Up By: Inland Sailor - Tuesday, Nov 08, 2005 at 15:27
Eeast Buffalo seems to be the route to take, But my map doesn't show Van Dammes Track, only Humffrays River Track and Sambar Spur track. Which is it?
FollowupID: 392080
Reply By: Crackles - Monday, Nov 07, 2005 at 22:44
Easiest way is via Myrtleford & in on the East Buffalo road, East Rilely road then the Wonnangatta track. Would have no hesitation in towing a camper trailer that route when wet. Only one river crossing as you enter the valley which is not normally too deep except after recent heavy rain.
West Buffalo route would require you to take Harry Shepards track which is a little steeper and best not done in the wet if you have a nervous passenger ;-)
All other routes in & out of the valley are best left to the experienced driver with a high clearance trailer & a powerful tow vehicle.
Get the Rooftops Bright to Mansfield Adventure Map for the best detail.
Cheers Craig.............
AnswerID: 138348
Follow Up By: Inland Sailor - Tuesday, Nov 08, 2005 at 15:24
Craig
My HEMA High Country map shows the East Buffalo Rd which appears to become the Humffray River track. The Map shows It intersects with the Riley Ck track. Is this what you are refering to?
FollowupID: 392078
Follow Up By: Crackles - Tuesday, Nov 08, 2005 at 17:39
Hello Sailor ;-) I suspect your Hema map is out of date. I have a 3rd edition and it has many tracks missing or shown open that no longer exhist. As previously mentioned get a copy of the Rooftops Bright to Mansfield Adventure Map for the best detail.
At Catherine Station you turn left on the East Buffalo road. You will pass Walshs then the West Humffray tracks on your left & the East/West divide track on your right. 2 kms further you will cross over Selwyn track (great divide). Turning right at the Humffray river track intersection you will be then on East Riley road. If your map shows Sambar spur at this point throw it away as it no longer exhists. (A new road was cut around the hill here.)This turns into the Wonnangatta track as you pass Van Dammes. Turn right at Rileys creek track & you drop into the Gatta.
I bet that confused you as I nearly lost myself trying to explain. Pretty staight forward when you are there & fairly well sign posted.
FollowupID: 392112
Follow Up By: Inland Sailor - Tuesday, Nov 08, 2005 at 21:52
Hi Craig
Thanks again, and Yep sounds confusing, but I'll get hold of a Rooftops map and that should clear it up.
Next question, best guess at the time the trip should take from Myrtleford to Catherine station, and then from there into the Wonnongatta.
PS Where are you from as you seem to know tis area well?
FollowupID: 392168
Follow Up By: Crackles - Tuesday, Nov 08, 2005 at 23:24
It's around a 3 hour drive from Myrtleford to the Homested site, probably just under an hour to Catherine Station depending on how fast you drive & how dusty it is. After alot of traffic it can get pretty bad.
I'm from Benalla & get up that way fairly regular in fact was clearing tracks with the Wangaratta 4x4 club around Mt Selwyn last weekend.
Unlike the 80's when it was one big bog hole Wonnangatta is an easy drive these days.
FollowupID: 392231
Reply By: Member- Rox (WA) - Monday, Nov 07, 2005 at 23:32
In Jan 05 I pulled a CT with Dingy on top (traveling round oz) via Dargo, Grant, Bulltown Spur, staircase upto the pinical, licola, Mt Wellington, Butchers country Tk & all the way to Mt Stirling. The track names may be out of order but a fantastic trip. I have a gutless std 80 series Diesel with a rear locker all on skinnies. I'll have to upload the track.. Have fun.
AnswerID: 138362
Follow Up By: geocacher (djcache) - Friday, Nov 11, 2005 at 04:58
Gees you know I've looked and looked and couldn't find a boat ramp in there anywhere!
Dave
FollowupID: 392713
Reply By: geocacher (djcache) - Friday, Nov 11, 2005 at 04:46
Hi Inland Sailor,
I've had a hunt around the hard drive.
If you click here you should download a pdf file with my track file overlaid on a map.
Any problems I'll email it to you if you post your address, but not til Monday as I'll be in the 'gatta all weekend.
Dave
AnswerID: 138911
Follow Up By: geocacher (djcache) - Friday, Nov 11, 2005 at 04:57
Bit more info. This track was recorded in March 04. Three vehicle convoy including GQ towing a T-Van.
Took 2 hrs 56 mins from Myrtleford.
Dave
FollowupID: 392712
Follow Up By: geocacher (djcache) - Friday, Nov 11, 2005 at 05:02
Alternatively there's a link to the pdf file on my 4wd website.
Link in signature or here.
Dunno if linking to pdf file as i did originally works. Spose I could test it but I've typed this now and it seems a pity to waste it.
Dave
FollowupID: 392714
