50mm 4wd tyre diameter increase
Submitted: Thursday, Nov 10, 2005 at 18:51
ThreadID: 27989 Views:6090 Replies:3 FollowUps:18
i was speaking to vic roads engineer today about proposed tyre diameter increase on 4wd to a max 50mm.
a few things he mentioned its only a proposal and has been for a cpl of years.
they will be sitting down around the 19th of december but he expects it to go on for a lot longer.
vic roads want to maintain 15mm increase only.
and the wording of pasenger car and passenger derivative can include patrols/cruisers ect.
the word 4wd passenger vehicle may well be the type of passenger vehicle you see carting people about in hire busses on fraser ect.
Reply By: Truckster (Vic) - Thursday, Nov 10, 2005 at 20:06
The engineer that did my truck yrs ago, told me then that other engineers were already going thru training on the new laws. Well that was horse bleep cause they still havent got the laws sorted out!
"sitting down 19th Dec".. The week before Xmas - they expect things to actually REALLY happen? LOL!
As I said in other thread
Dont get excited yet fellas...
It will go thru each states governing body 100 times in the next 10 years, be argued against/for each time, then modified, then they will bring out Draft # 19048023984023948.b-s1 and then and only then *MAY* it happen.
By the time it happens,there will be no oil left.
PS.. Wheres my shoelaces..?
AnswerID: 138859
Follow Up By: Diamond (Vic) - Thursday, Nov 10, 2005 at 21:00
Follow Up By: gramps - Thursday, Nov 10, 2005 at 21:15
Last seen in the mouth of a rather large marsupial :)))))
FollowupID: 392633
Follow Up By: Wombat - Thursday, Nov 10, 2005 at 22:08
I think you'll find your shoelaces in the same place as your t-shirts.
FollowupID: 392644
Follow Up By: gramps - Thursday, Nov 10, 2005 at 23:16
In the bit bucket :)
FollowupID: 392677
Reply By: Member - Paul P (Bris) - Thursday, Nov 10, 2005 at 20:38
Oh Yes
It took a decade for the States to agree to a set of national traffic laws. Which they still agree to disagree on. It all started with different rail gauges and has continued for over 200 years.
Settle back and relax. Yours and my tax payers money will allow for some interstate shopping time for some "decision makers" for at least a few more years.
Paul
AnswerID: 138864
Follow Up By: blown4by - Thursday, Nov 10, 2005 at 21:01
Have a look at the wheels and tyres section of the draft code of practice for light vehicles which is open for public comment at the moment. You will find it at www.dotars.gov.au. One thing you need to keep in mind is the bigger tyre/wheel diameter you run the less brake efficiency you will get for a given size disc or drum brake assy.
FollowupID: 392627
Follow Up By: Member - Phil G (SA) - Thursday, Nov 10, 2005 at 21:14
Not so sure about the braking thing. Aren't the same size brakes still slowing down the same size vehicle???
FollowupID: 392632
Follow Up By: Truckster (Vic) - Thursday, Nov 10, 2005 at 22:22
Bigger wheels - worse the braking. Thats why a Braking test is done to get bigger tires engineered.
FollowupID: 392648
Follow Up By: gramps - Thursday, Nov 10, 2005 at 23:19
Yeah, I've seen it somewhere that you should stay within 3% of the original diameter??? or you risk the possibility of brake failure.
FollowupID: 392679
Follow Up By: blown4by - Friday, Nov 11, 2005 at 10:36
The reason the brake efficiency reduces is because the lever effect increases.The distance from where the tyres contact the road to the centre of the axle increases so it makes it harder for the brakes to stop the vehicle.
FollowupID: 392746
Reply By: Member - Phil G (SA) - Thursday, Nov 10, 2005 at 21:16
Strikes me that 15mm is a lot for a mini, and its bugger all for a big 4wd. It would be more sensible to express these limits as a percentage of original diameter. So they could set a limit of say 4% which is sensible for all vehicles, and fits in with one profile difference.
AnswerID: 138873
Follow Up By: Sky Pilot - Thursday, Nov 10, 2005 at 21:41
I don't think that most people who want to put bigger wheels on their 4WDs would be happy with one profile size. 4% will create a very small height difference. When you look at the number of 4WDs running 33's and 35's with a slight body lift, they would be most miffed with one tyre profile size increase.
From my point of view, as long as I can purchase a set of serious off road tyres in the legal size, I am happy with that. The problem has been and still is to an extent that the newer sizes come as car type tyres and there is nothing in the way of a tough tyre that could safely go on an outback trip. To get a decent tyre, you usually have to go up a couple of sizes and they are more than 15mm larger in diameter.
FollowupID: 392639
Follow Up By: Member - Phil G (SA) - Thursday, Nov 10, 2005 at 21:53
4% would allow most LandCruiser and Patrol owners to run 285/75/16 and Prado/Mitsubishi owners etc to run 265/75 or 235/85R16. These 3 sizes are the best for outback travel.
If people wanted to go bigger than 4% then I reckon its up to them to get it engineered. People with bigger tyres than that are either show ponies or weekend warriers - its not a necessity.
FollowupID: 392641
Follow Up By: Truckster (Vic) - Thursday, Nov 10, 2005 at 22:24
1) not everyone is into outback travel.
2) that are either show ponies or weekend warriers: so what would they call you?
FollowupID: 392649
Follow Up By: Neetas - Thursday, Nov 10, 2005 at 22:27
Having done these calcs for a 2005 GU, I can suggest that 265/75 16's are the max legal size offering a 14mm height diff. 285/75 16's make a 44mm diff, comparing to the stock 275/65 17's. Even looking at the 44mm diff, I assume this only equates to a clearance gain of 22mm, as the other 22mm is on the other side of the tyre. Not a lot really, the real gain is in the durability of the tyre assuming you are buying good quality off-road tyres.
A good site for comparing wheel sizes to calc OD increases and speedo errors is http://www.1010tires.com/TireSizeCalculator.asp?
FollowupID: 392651
Follow Up By: Truckster (Vic) - Thursday, Nov 10, 2005 at 22:38
Neetas.
The question is though : Is it ACTUAL measured size of the tire - OR the marked side of the tire?
There are threads on several forums asking this.
EG: some 285/75's are 10mm different in MEASURED size to others. As are other sized tires. Some 33's measure 32actual
FollowupID: 392654
Follow Up By: Sky Pilot - Thursday, Nov 10, 2005 at 23:38
Surely there must be a variance for tyre brand of +/- x%. It could be as high as 3%.
FollowupID: 392687
Follow Up By: Member - John C (QLD) - Friday, Nov 11, 2005 at 09:00
What about depth of tread in your calcs.
Most new tyres I have seen have 9 to 13mm of tread, some MTs more.
Coopers being one that offers extra tread depth.
They may have to look at offering less tread depth to stay legal :-)
I think this is getting all too hard.
Pump your tyres up hard and you most probably gain 5mm over standard road pressure.
Let them down to 20 psi and you must loose about 15mm.
Will the authorities confirm at what tyre pressure these measurements are done at if it is the true dimension?
I think it has to be worked on tyre placard size, rather than actual size.
Could be a few stretched tape measures otherwise :-)
"Really officer, my 285/75 16 tyre are under 32" OD, look what my tape measure shows!" And measure on the spot.
FollowupID: 392731
Follow Up By: Scubaroo - Friday, Nov 11, 2005 at 10:18
One profile difference is fine for the many drivers who are stuck with a tyre size that doesn't have any light truck construction or mud tread options! e.g Pajero - 265/70R16 - try finding a legal mud tyre, and the only AT option in LT in that size is the BF Goodrich AT. Tyre manufacturers just don't want to cater to this size unless it's passenger construction - even Cooper STs are passenger construction in this size.
FollowupID: 392742
Follow Up By: Member - Phil G (SA) - Friday, Nov 11, 2005 at 16:40
Truckster said
" 1) not everyone is into outback travel. "
Couldn't agree more - my reference was purely in response to Sky Pilot's who stated that bigger tyres were needed for safe outback travel - which I don't think is the case.
And what would they call me?? I'm sure you can come up with something :-))
phil
FollowupID: 392804
