Patrol diesel engine mounts
Submitted: Sunday, Nov 13, 2005 at 20:23
tanksturbodiesel
I have just looked at a 91 Nissan patrol that came from factory with the Nissan RB30 6cyl engine, however the second owner being a diesel mechanic did not like petrol and has dumped a TD42 6cyl Diesel engine in it with an after market turbo kit too.
I have the dilemma of the engine mounts not lining up, so can anyone please help me in the case of does the RB30 motor have different sized mounting brackets or positions to the TD42 motor, or do i have to get some brackets made up to suit the positioning of the mounts on the chassy rails to suit the TD42 block????
If anyone can help asap please email me on mjobrian@optusnet.com.au
Cheers Michael
Reply By: Billowaggi - Sunday, Nov 13, 2005 at 23:34
I may stand corrected here but I think the RB30 powered Patrol had different gearbox and diffs to the TD42 , MUCH LIGHTER if they have not also been changed the torque of the turbo diesel is going to cause a big crunch somewhere else in the driveline.
Regards Ken.
139241
Reply By: tanksturbodiesel - Monday, Nov 14, 2005 at 01:17
Thanks ken i know about the diffs and running gear all that has been changed along with the engine, the queary i have is with the engine mounts if they are the same used for both engines or if the TD42 engine mounts are bigger and different to the RB30 engine, cheers Michael
139251
Reply By: searay27 - Wednesday, Nov 23, 2005 at 20:56
hey call nissan and match part numbers I know petrol l 4.2 are the same as rb 30
140691
Follow Up By: tanksturbodiesel - Thursday, Nov 24, 2005 at 20:29
thanks for your reply, i have found out from an engineering mate in my club that the RB30 motor does have different positions for the engine mount on the chassy, therefor to put a TD42 motor in there you would have to unpick the mounts from the chassy and reweld them in the position you need, then have it all engineered, in other words very costly. Thanks for all ur support, cheers michael
394489
