Location for a UHF radio in a LC 100 series?
Submitted: Sunday, Nov 20, 2005 at 19:31
Tom57
Wondering where's the bset palce to put a
UHF radio (Icon 400Pro) in the Landcruiser 100? I have read all the ads in 4x4 mags and it appears that the only two
places are on the dash or replace the roof console with a "Dept of the Interior" centre console. Suggestions welcome!
Many thanks
Tom
Reply By: cobber - Sunday, Nov 20, 2005 at 19:47
Hi Tom57..............I have my Icom 400pro mounted via 2 self tapping screws just to the left of my knee, and arms length just fine for adjusting the set when needed......
140161
Reply By: P.G. (Tas) - Sunday, Nov 20, 2005 at 20:35
G'day Tom, when I had my L/C 100, I replaced the average double din Toyota stereo with a single din Alpine unit, and mounted the El;ectrophone UHF directly under it in the dash .
It was very neat and looked as though it had been factory fitted.
Hope this helps.
140166
Follow Up By: Tom57 - Monday, Nov 21, 2005 at 18:39
Thanks Peter.
Is your LC 100 a recent model. You say that it was average - I hope they updated the stereo unit in the new facelift models? I haven't pick-up
mine yet - this Thursday if I'm lucky - hence the enquiry re: the place to put a
UHF radio.
Tom
393964
Reply By: Rock Crawler - Sunday, Nov 20, 2005 at 22:44
had this issue also not lond ago . I stripped the concole and dash to find a place . I spotted a gap in the concole that works
well !MPG:3!
here is a pic of what it looks like . you only get to see 20 mm of the radio , the rest is hidden in the concole
140183
Reply By: wheeler - Monday, Nov 21, 2005 at 07:52
I have a GME tx3400 remote head. Radio is mounted under the pass
seat and control head is mounted on centre console forward of the gear lever. Works great. And looks neat.
140198
Reply By: ThePunter - Monday, Nov 21, 2005 at 10:52
Check out the following thread, lots of good information.
LC 100 UHF
140221
Follow Up By: ThePunter - Monday, Nov 21, 2005 at 10:56
Let's try that again.
Post ID 27585
393899
Reply By: stans truck - Monday, Nov 21, 2005 at 12:11
hi there replaced the whole lot icom sits above new mp3 player looks like factory and bye the way i did a costing and cheaper to do that way than roof console bye the time you buy and get it fitter and then install your radio its lot cheaper to go the other way ,cost new radio mp3 $200on spiecial fitting charge $80 and uhf same also you dont have to look up all the time to fiddle with the radio its eye level and much safer while driving regards stan.
140228
Reply By: P.G. (Tas) - Monday, Nov 21, 2005 at 20:36
Hi again Tom. The factory stereo in most cruisers/patrols are fine for Jo Average, but I enjoy my music (and like hearing it cleanly above the gravel flying off the
wheels), and at these levels the standard sound is VERY average! The standard speakers are fine (quite good actually and will handle a clean 50W deck), it's just that the standard deck lacks power. Whatever they rate the deck at is grossly over exagerated. I think they are about 4-6 watts per channel in real terms.
A good 50W+50W deck will make the world of difference, without going over the top or paying a fortune.
140307
Reply By: goodpal50 - Tuesday, Nov 22, 2005 at 18:42
Making the assumption that you do not smoke i suggest the following that I did to my 100 series.
Remove the h ashtray. Get a welder mate to make up an aluminium plate that fits neatly into the slide and weld on at about 45% upwards another plate about 40mm in height. Drill a hole in the horizontal plate and tap it and fit a screw (grub screw). When you insert the horizontal plate you screw inthe screw that locates the aluminium firmly into place. Screw the radio to the 45% plate. Drill a hole through the back of the ashtray housing for the power and aerial cables.
When you sell the vehicle undo the grub screw, replace the ashtray and no one would ever know you had a UHF in.
I have taken this on some rough tracks and never had aproblem and it is cheap.
Mike
140462
Follow Up By: Tom57 - Wednesday, Nov 23, 2005 at 19:28
Thanks Mike
I appreciate the suggestion. Will look into it!
Tom
394296
