nissan dynoed today
Submitted: Friday, Nov 25, 2005 at 18:33
ThreadID: 28370 Views:2285 Replies:4 FollowUps:2
evening all
had the 4.2 nissan patrol dynoed today new exhaust being fitted next week
anybody know what the maximum output be dyno came up with max 78.8kw on back wheels
steve
Reply By: Member - Trevor R (QLD) - Friday, Nov 25, 2005 at 18:45
Hi steve,
Don't remember what the figures are of a standard 4.2 turbo but mine at the rear wheels is 88-89kw and my uncle (who has had the same work done on his) has 95kw. I'm sure you will find each dyno will give varying figures for the same vehicle.
Remember I have the 3" exhaust plus turbo mods so if you have 79kw now I would think you will be suprised at the figure after the modifications.
Best of luck Trevor.
AnswerID: 141011
Follow Up By: Member - Trevor R (QLD) - Saturday, Nov 26, 2005 at 09:01
Steve,
I just remembered this morning, my uncle's bog standard 4.2 turbo went from 66kw to 95kw once the exhaust and turbo was modified at MTQ.
I suggest if you already have 79kw then you must have your car running very sweetly already and may have a real weapon when you have had the work done.
Hope this helps.Trevor.
FollowupID: 394755
Reply By: ACDC - Friday, Nov 25, 2005 at 21:31
You could put it on 10 dyno's and get 10 different results,as long as you end up with more than when you started and it runs better on the same dyno is what counts.
AnswerID: 141041
Reply By: Member - John - Saturday, Nov 26, 2005 at 09:11
Gob, I started with 72 kW at the rear wheels, after exhaust, dump pipe, MTQ modded turbo and tuned at MTQ in Toowoomba, 120 kW, to say very happy, an understatement. Still need to dyno after fitting i/cooler. Hope this helps?
John and Jan
AnswerID: 141079
Follow Up By: Member - Trevor R (QLD) - Saturday, Nov 26, 2005 at 22:25
Holy cr@p John how old is yours and what K's. You have just made me extremely jealous, I am happy with the work the guys up at Toowoomba done on mine but as I said above I only got 88.8kw from their stage 2 powerup. I have just recently added the safari intercooler up to this setup as well, I can't say I've noticed a huge difference yet but have yet to put the big trailer on the back and go for a run.
Would like any info you can give on how they got so much out of yours and so little (in comparison) out of mine
Cheers Trevor.
FollowupID: 394808
Reply By: GOB & denny vic member - Saturday, Nov 26, 2005 at 19:14
goodday gents
gu already 4.2tdi just getting the exhaust done for starters and then see how it goes hope to get the turbo tickled along the waymay just get an extra couple of psi added
steve
AnswerID: 141143
