Saturday, Nov 26, 2005 at 12:33
Most ally bars are a replacment of the origional steel bumper (or plastic bumper on later models I spose) but wouldn't weigh much more if any at all than standard. The long range
tank is at the rear so it would have a minimal impact on the front tortion bars. Nah, there's no legal issue that I'm aware of with trimming bump stops, even with my tortion bars pre loaded a small amount I still very rarley hit my trimmed bump stops with up travel as there is just not enough weight in the vehicle unless it's facing down a steep
hill frontwards or somthing. I couldn't even get my wishbones level by jacking as close to the front wheel as possible when I was changing my CV boot the other week, I actually had to jack the opposite rear corner of the vehicle up to shift weight onto the front to push the fronnt
suspension up. Heavy duty tortion bars I would imagine would make this even worse. But yeah it's not a major job to trim them, just need a vice, some silcone spray helps and a haxsaw. Just remeber that these are pretty tough rubber so trying to haxsaw them without a lubricant will heat the crap out of the haxsaw and make it very hard work, you can use CRC or WD40 etc but it becomes VERY messy as you end up with black crap all over you as the rubber sheds a black dust which stick to the CRC and get's all over you.
Mine were a bit of a PITA to get to the bolts on, but I used an air rachet which made the job a 5 min one instead of a 30min one. Basically with an IFS vehicle that's about all you can do if you don't want to spend BIG $$$. So just compentsate that by making sure you have as much travel in your rear
suspension and if you really want to go and do hard core stuff think about a front Diff Lock. I've been some pretty incredible
places with my IFS Surf with stock
suspension, I've only just upgraded the rear to give me some quite insain travel/articulation, I have no diff locks. So don't get too caught up in it. Mind you, I do love my new rear setup! :-)))) It travels SO much that the drive shaft hits the
fuel tank stone guard at full drop and makes a tapping clucking noise as you traverse the large obsticle. It goes so far that I've had to resort to some industrial type cable ties to gold my 2" HD King springs in so they don't fall out! LOL
Good luck with it anyway, I'm sure you'll work it out. These forums have saved me SO MANY $$$ over the years while building up my rig, it just takes time to sort through some of the crap and differing opinions. And confidence to give some of this stuff a go yourself, I did my entire rear
suspension setup myself, including firestone coil rites, modified 9909 Ranchos and springs and before I started reading forums I didn't even know which end of the screw driver to use! ;-)
394769
