1994 TD 2.5 Triton
Submitted: Friday, Dec 02, 2005 at 22:08
ThreadID: 28583 Views:3065 Replies:4 FollowUps:1
Hi all,
After some info if i can, 1994 2.5 TD mitsubishi triton, Not getting any glow plugs on cold start.
Remove the plug from the Coolant temp sensor and the glow plugs work.
I am guessing the Temp sensor is buggered but i am unsure what resistance i am ment to get across it.
Any Help would be appreciated...
Chris
Reply By: Eric Experience. - Friday, Dec 02, 2005 at 23:09
Chris.
3000 ohms at 20 deg C Eric.
AnswerID: 142192
Reply By: chriswoo - Saturday, Dec 03, 2005 at 10:30
Thanks for that,
i am not getting any where near that. Yet the temp guage is working ok. time for a new sensor i think.
chris
AnswerID: 142231
Follow Up By: chriswoo - Saturday, Dec 03, 2005 at 18:49
Eric, have you pulled one of these out? and if you have how did you do it! They are in such a spot that you can't get a socket over the sensor or a ring spanner/open ender in there??
And where did you get those Numbers from: 3k @ 20 deg c. I am chasing a workshop manual and am having zero luck getting any books on the triton...
FollowupID: 395852
Reply By: Eric Experience. - Saturday, Dec 03, 2005 at 22:31
Chris.
I have a factory workshop manual. I have not had any problems at all so have not tried to remove a sender, the temp gauge and the glow plugs use seperate sensors, Eric.
AnswerID: 142299
Reply By: chriswoo - Saturday, Dec 03, 2005 at 22:50
G'day Eric,
The Temp Sender i have been testing is the one at ther front of the head on the top. This sensor drives the guage as grounding it out drives the temp gauge hard to the "hot" Position.
That being the case, if you don't mind me asking, where is the "Glow Plugs Water Temp" sensor located??
Also where did you get your Factory Manual from??
Thank's
Chris.
AnswerID: 142303
