landcruiser carby required
Submitted: Sunday, Dec 04, 2005 at 13:43
ThreadID: 28603 Views:2447 Replies:5 FollowUps:0
Am searching for a Weber or Holley carby to fit up to a 60 series landcruiser.
Am also looking for a decent alternator ( presently only has a 45 amp)
Reply By: Peter 2 - Sunday, Dec 04, 2005 at 14:25
Much better to stick with the standard carby as Holley's do not work well off road on steep climbs and angles and bumpy sections. They can be modified but on the whole more trouble than it is worth.
Work well on the road though. BTDT as they say.
Never seen webers on cruiser motor.
Alternator can be from anythingas long as it is 12v, can either use existing regulator or use internal one that may come with another alternator.
AnswerID: 142340
Reply By: Boc1971 - Sunday, Dec 04, 2005 at 15:17
Best bet would be to look on ebay for carbi's - i have a holley 650 double pumper(Spreadbore ) with manual secondaries i am going to sell soon - taken of my boat ( 350 chev worked ) not sure if you would want a carbi this size but if you do - drop me a line ( i am going back to vacuum secondaries )
Frank
AnswerID: 142344
Reply By: Diamond (Vic) - Sunday, Dec 04, 2005 at 16:21
get your stock one recoed much better carby.
AnswerID: 142350
Reply By: BenSpoon - Sunday, Dec 04, 2005 at 17:37
Its hassles and cash to get a holley on there if you dont already have one. Adapters for the manifold, changing the accellerator cable connections and movements, a new air filter box or adapter to existing....
I machined up my own adapter from a blank, but even after it was all done and installed there were still problems with the auto choke and fast idle. I'd recommend a rebuild on your existing one- you at least know it will work and tune perfectly when you bolt it back in.
Quokka has a number of holley 500s for around $50-$100.
AnswerID: 142359
Reply By: ringa - Friday, Dec 09, 2005 at 00:05
Get a Weber from an Xf Falcon they are a good carby, and any decent Tig welder can fill the bolt holes and then you just redrill the manifold to suit the weber, I did this Mod to a Sixty series (2F) Engine, and it made a big difference to starting, low rev response, and gave much better fuel consumtion, especially when towing a caravan. did not need to change jets, The Throttle cable can be changed to suit
fairly easily. cheers
Ringa
AnswerID: 143051
