EGT gauge
Submitted: Wednesday, Dec 07, 2005 at 09:53
Gerry
Hi all,
I am thinking of fitting an exhaust gas temperature (EGT) gauge to my 100 series, a 1HZ with Denco aftermarket turbo. Where in SA is a good place to find one and roughly how much should I pay? Also, what temperature range is normal and at what temperature should I start backing off? I have searched the archives but can't seem to find any definitive answers.
Thanks in advance.
Gerry
Reply By: Motherhen - Wednesday, Dec 07, 2005 at 12:11
Reply By: Member - Roachie (SA) - Wednesday, Dec 07, 2005 at 13:19
I can thoroughly recommend the Thermoguard unit. I have the Denco turbo upgrade done to my Patrol and have recently added an extra thermocouple probe; so I now can switch between above turbe and below turbo temps. I know this overkill, but I have read up a lot about this issue. Ian from Thermoguard says (and I agree with his thought process) that the "before" turbo temperature is more important to know, because this is the temp of the gases that are gunna be hitting your turbine and may cause it very expensive damage. The thing I have learned recently is that a turbo is a "user" of heat (not a "creator" of heat). This is evidenced by the fact that I can switch between the 2 probes and find that the input temp can be around 500oC and the below temp is around 380oC!! The 2 probes are about 250mm apart!!
Despite Ian's belief that the best place for the thermocouple is above the turbo, if you talk to the industry "experts" (I hate that word), they all apparently work off temp's below the turbo for setting-up their and monitoring these devices. So, that is why I chose to have a bob each way. I still only use the one in-cab monitor, but have fitted a DPDT switch so I can see what either probe is registering at any given time.
You will probably install your probe in the ready-made hole provided below the turbo, and I would suggest that you wouldn't want to ever see that temp go above 520oC.
Hope this helps
Roachie
142787
Follow Up By: RedGibber - Thursday, Dec 08, 2005 at 19:57
Roachie,
Out of interest, is there a fixed relationship between the "above turbo" and "below turbo" EGTs e.g. always say about 180 degrees different? Or is it a ratio i.e. always roughly so much % different?
Maybe you can see where I'm heading with this..... ;-)
396519
Follow Up By: Member - Roachie (SA) - Thursday, Dec 08, 2005 at 23:06
No mate, no real relation between the 2.
When I'm accelerating hard and boost is up between 10 and 15psi, that is when the biggest gap seems to occur between the 2 temps, say up to 130oC difference.
When driving along steady at 110kph flat road etc and boost is around 6psi, the difference may only be 50oC or so.
Roachie
396554
Follow Up By: RedGibber - Friday, Dec 09, 2005 at 20:56
Thanks for the info Roachie.
I recently fitted
Beaudesert's 3" system to my '02 TD42T, and in the dump pipe there's a BSP thread (blanked) for inserting an EGT probe.
Based on yours, and a whole lot of other comments/discussions on various forums I'll get hold of a Thermoguard unit......and then monitor it!! LOL
Andy
396660
Reply By: Truckster (Vic) - Wednesday, Dec 07, 2005 at 14:43
[ View Image]
I have the VDO gauges in
mine. Look sweet and work
well day or night
142803
Follow Up By: Member - John - Thursday, Dec 08, 2005 at 08:05
Truckster, excuse my ignorance, but how do you post pics using the hyper link? Thanks in advance. John
396432
Follow Up By: Member - John - Saturday, Dec 10, 2005 at 08:56
Thank you Truckster. I will endevour to see if I can master this technology.
396712
Reply By: Member - John - Thursday, Dec 08, 2005 at 08:03
Gerry, I bought the Isspro Colour coded gauge, makes it very easy to check at a glance, bought it on e-bay from the states. Can't remember how much or who from.
http://domain.com/C:\Documents and Settings\John\Desktop
Hope the link works?
142932
Follow Up By: Member - John - Thursday, Dec 08, 2005 at 08:04
Guess the link didn't work, doh!
396431
Follow Up By: Truckster (Vic) - Friday, Dec 09, 2005 at 22:56
John.
You need to upload the photo to a server in the internet.
www.photobucket.com is a good free place
once uploaded post the URL that it will show you on photobucket like this inc the brackets
<img src="
http://www.photobucket.com/....what ever it says to post">
396677
Follow Up By: Member - John - Saturday, Dec 10, 2005 at 09:18
[ View Image]
396715
Follow Up By: Truckster (Vic) - Sunday, Dec 11, 2005 at 22:12
Give the filename a simple name like 1.jpg and try that .. easier to get right.
396882
Reply By: prado_95 - Friday, Dec 09, 2005 at 20:54
I use ISSPRO, mounted after the turbo. Its a nice colur coded face that makes it easy to see at a glance - mines on deg F.
Truckline (WINGFIELD 08 8340 6500) should have them (or be able to get them). Check www.isspro.com for the gauges.
Mine is the R607VW (which is colur coded for AFTER the turbo).
Dont exceed 1100F post turbo (about 1250F pre turbo on
mine) or EVER you'll
cook the turbo. Normal operation should be about 650F (
well it is on
mine).
Post turbo installation will save your turbo if the thermocouple ever breaks off, but could be down up to 350F (depends on fuelling levels and exhaust system).
Also dont try for too much boost on the 1HZ, or you will have issues. About 7.5PSI is the limit. This means you dont want one of those boost gauges that read to 30PSI!
Dave
143170
Follow Up By: Member - John - Saturday, Dec 10, 2005 at 09:27
[ View Image]
Is that the gauge you have?
396716
Follow Up By: prado_95 - Sunday, Dec 11, 2005 at 21:43
Thats the one, and Boost looks same too!
Somebody made a good choice :-)
Dave
396880
Reply By: Voxson (Adelaide) - Sunday, Dec 11, 2005 at 22:35
Just a test...
[ View Image]
143395
