Thursday, Dec 08, 2005 at 12:51
Most likely a microbiological contanimation which is a particular problem in diesel and aviation turbine fuels. It is probably the single biggest problem faced by scientists trying to develop storage solutions for these fuels.
The most common contamination is from a fungus-like micro-organism called Cladisporium Resinae. The
fuel in storage tanks can sometimes develop a dirty slime at the fuel/
water interface. Apart from being unsightly it can block
tank strainers and vehicle
fuel filters. If left unattended it can spoil the
fuel and contribute to
tank corrosion. These airborne spores which occur naturally in diesel, have an oxygen source from the
water and use the elements as a food source to propagate growth. It becomes evident because of the fact that filters clog up, vehicles may lose power and their overall performance deteriorates.
The conventional method of eradicating the bug is to use a biocide. However, this has two major drawbacks in that both the
water and the dead bug remains in the system and removal is costly.
In the aviation world, regular
fuel samples are taken from various
places in the airframe and engine fuels systems to try and pick the growth up long before it becomes a problem......nowhere to
park up there if the engine(s) stop. Super fine 10 micron filters in the airframe
fuel systems become blocked very quickly and go into bypass mode but it don't take long to contanimate the engine FCU once this happens.
Best solution is to try and prevent growth and that essentially means removing the
water from the
fuel to be successful - now here's an opportunity for those inventors among you to develop a gadget to put in the inlet of your
fuel tank to try and get the
water out before the
fuel is pumped into your
tank(s). The alternative is to use a biocide and if you do get a big contanimation flushing the entire
fuel system several time to get as many of the spore out that you can. Good luck - there ain't an easy solution to this particular
fuel storage problem.
(PS this stuff can't survive in leaded fuels so it is not a problem for storage of AVGAS or for that matter the leaded gasoline we used to use).
142971
Follow Up By: Member - Bill S (NSW) - Saturday, Dec 10, 2005 at 19:45
BOY OH BOY, How wrong can that statment be wake up guys I am sick of telling you all . Prevent ALL growth FIT FITCH check it out , IT is advertised on this site and that is why it is advertised.
Regards BILLS
396776
