Watts to run AC
Submitted: Thursday, Dec 22, 2005 at 14:20
Member - Camper (SA)
After the migraine I got from doing the calculations on the recent post for "The Electrically Minded" it occured to me to ask how many watts the average car air con needs to run flat chat.
Any takers?
I often wonder if those who run their AC continuously realise that the cooling doesn't come from the good fairy in the dash but is a real drain on their
fuel dollar.
Camper
Reply By: TerraFirma - Thursday, Dec 22, 2005 at 14:38
Not sure what you mean as the watts required to run a car air con is produced by the alternator with only a very small load on the engine. (Newer cars). For example my new Hilux does not vary in it's
fuel consumption with the Air Conditioner on or off. So with that in mind the watts required are being freely generated by the vehicles alternator. Older model vehicles do suffer an increased load on the engine when running the Air Conditioner Clutch , that may equate to an increase in
fuel consumption of up to 10% but it has no effect whatsoever on my new Hilux.
145075
Follow Up By: hl - Thursday, Dec 22, 2005 at 15:09
Well.. watts or no watts... the compressor does use power, and quite a lot actually. It would at least be the equivalent of a 3 or 4 hp unit for your home (about 3kw) Someone might know the actual figures, but I seem to remember that they have a quite substantial "btu" rating.
In my 93 Falcon it uses about 1l/100k more, in my 3.0 Tdi Patrol it does not seem to be that noticeable, but I am sure that there would be a difference.
398593
Follow Up By: signman - Thursday, Dec 22, 2005 at 15:14
Wow..the system used must be a template for perpetual motion. So your a/c uses no friction, no resistance, no load ???
398594
Follow Up By: GaryInOz (Vic) - Thursday, Dec 22, 2005 at 17:33
TerraFirma and HL,
The only power the airconditioner uses from the alternator (over that used for the internal fan) is to power the electric clutch and the air conditioning condenser fan (under bonnet). The clutch uses about 10-15 amps, and the fan another 10 amps. The actual energy for the compression of the refrigerant gas comes from the engine, NOT the alternator.
Yes it does affect
fuel consumption, more so up north than in Tassie (usually 5-15%).
398615
Follow Up By: Nudenut - Thursday, Dec 22, 2005 at 18:32
it doesnt matter wherthe energy comes from.....it can all be counted as watts
398636
Follow Up By: hl - Thursday, Dec 22, 2005 at 22:13
Exactly.. I didn't specifically say those kilowatts come out of the alternator/battery. Sure, the clutch and fan do, but they are only a minor part of the equation. (I doubt that the clutch uses as much as 15 amps, actually, but I could be wrong)
398686
Reply By: Bullwinkle - Thursday, Dec 22, 2005 at 15:13
It's not only electrical power used to run your air-con. Engine power also ( through the effort needed to turn the compressor via the belt ) The more load you pull out of an alternator, the more power is taken from your engine. The compressor clutch pulls very little current compared to the blower fan which actually moves the air round the cab. I've been told the total horse power of a Land Cruiser air-con is just under 1/2 horse.( 380W - about ) But, not all the 380W has to come from your electrical system rather in total from the engine. Not much really.
145088
Reply By: Rosco - Qld - Thursday, Dec 22, 2005 at 15:16
Camper
I seem to recall having your windows closed with the AC on is similar to driving with the AC off but the windows open. Apparently the extra drag from reduced aerodynamics is more or less equivalent to the extra hp involved in running the compressor.
Mind you ... the Fender has the aerodynamics of a brick so I don't suppose it really matters in my case ..... :o)
Rosco
145090
Reply By: TerraFirma - Thursday, Dec 22, 2005 at 15:23
Anyway there's nothing you can do about the power the watts or the whatever you feel it takes to run your air conditioner, other than turn the bleep er off..! Then again you could install a Finch
Fuel System and the increase in power would easily accomdate for the power used by the air conditioner belt/clutch. Off course you could double that again by adding the Cyclone which would swirl the combustion better for more power again.
145092
Reply By: chevypower - Thursday, Dec 22, 2005 at 15:24
I monitored the
fuel consumption closely in dads V8 Caprice with a/c on and a/c off with different drivign styles, and worked out it costs arount 10c per hour! to run the A/C - other cars may differ slightly, but as for me, the only reason i would EVER switch off the AC to save
fuel, is if i was about to run out, and trying to make it to the next
fuel station
145093
Reply By: ferris - Thursday, Dec 22, 2005 at 17:45
I probably should have posted this on your previous thread, about converting 240 v to 12 and vice versa. An old autoelec gave me this advice about converting the figures. Roughly in round figures the watts remain the same for both voltages. So if you fan is drawing 72 watts at 240 volts it will draw 72 watts at 12 volts. Add in about 10% for inefficiencies in your invertor, your fan will be drawing around 80 watts at 12 volts in round figures. That saves on doing a whole heap of maths, which I always hated.
Thats the easy part. As the voltage reduces the current increases. At 240 volt your 72 watt fan draws 0.3 amps. At 12 volts it draws 6 amps.
An analagy using
water: Volts is the hose diameter, watts is the
water volume and amps are the
water pressure. As the hose size decreases, you need to increase the
water pressure to keep the same volume going through the hose! Okay I'm no expert on all this, and I'm happy to stand corrected. All the best for Christmas and the New Year.
Cheers Ferris
145123
Reply By: Nudenut - Thursday, Dec 22, 2005 at 17:49
mmmm...
used to have all input figures for older style
York (alias ford, chrysler and gmh0 compressors. If i recall correctly, the biggest
York ( a 10 cubic inch displacement) at maximum rpm (7000?) would do around 5 ton of refrigeration capacity at airconditioning duty ratings.
this equates to around 15kWr in metric or approx 5hp airconditioner in old terms
it also has to with size of evaporator V interior of car to correctly work it out, but as rough guide I would estimate the equivalent of 2hp unit at maximum speed...giving or taking a bit for additional (that i havent factored in) thermal losses across the exterior skin of the cabin
145124
Follow Up By: Nudenut - Thursday, Dec 22, 2005 at 18:33
what a silly question Camper....you dont want to be cool when temps hit 35+?
398637
Reply By: Kiwi Kia - Thursday, Dec 22, 2005 at 20:53
Hi happy campers :-)) 746 watts = 1 hp.
How much watts / hp does the air con drag out of your engine,
well I like the numbers of 5 to 7 hp = (3.7 to 5.2 kw) !
You can easily 'feel' this your self by taking your foot off the accelerator and turning the air con on / off when descending a steep
hill. One of my vehicles tends to 'run away' a bit when descending a long steep
hill so I flick the air con on and the vehicle maintains speed as if I was feathering the brakes (same thing happens if you turn on the head lights as alternators can drag the same sort of kw out of the engine).
This is a good 4wd trick when descending very steep terrain off road (stay slow, stay in control). Keeping your foot on the brakes when descending a thousand feet or so over rough rocky terain is a pain in the butt if your vehicle tends to gain speed without braking. By turning on the air con you can keep both feet on the floor and not touch a pedal.
Modern engine management systems up the idleing speed automatically when you turn on the air con.
145155
Follow Up By: arthurking83 - Thursday, Dec 22, 2005 at 22:24
hill. One of my vehicles tends to 'run away' a bit..........
Yeah but it depends if you have an electric condenser fan or if it relies on the engine fan too!
My Rodeo does what you describe, but my Saab doesn't!
Guess which one has electric thermo fans!
So my guess on the extra fuel consumption you get when running the aircon also is taken up by the engine fan! And also the available engine power to start with!!
A piddly 2 lt 4cyl will invariable lose more fuel consumption with the aircon on, when compared to what a 6.7lt V8 turbo diesel will under the same conditions.
398690
Reply By: Ken - Thursday, Dec 22, 2005 at 22:28
HHMMM so now we have 12v powered airconditioners in vehicles do we ?? I don't think so Kia. If you mean the electrical load is only slightly increased by running the aircon you are right. The real power to run the compressor comes from the engine mate ! The engine gets its power from the fuel, more power consumed, more fuel consumed, pretty simple.
145175
Follow Up By: Kiwi Kia - Thursday, Dec 22, 2005 at 22:55
Yep, you are right. If you read carefully I did not mention electrical anywhere! The word ENGINE is used. I am talking about the air con compressor not the fan! As I stated it is the air con compressor that puts a drag load on the engine.
Most manufacturers quote their engine power in kw's and not hp these days, 746 watts (or 0.75 kw) = 1 hp.
And please don't ask about all the different ways of calculating hp eg. indicated hp, rated hp, RAC hp, brake hp etc. I know that they are all different.
398695
Reply By: Gerry - Friday, Dec 23, 2005 at 10:38
At the end of the day, it ALL comes back to an additional load on the engine - even the extra electrical load, which in turn requires more engine power to turn the alternator. As said previously, energy for everything in your vehicle is supplied via the fuel in, therefore, any additional energy required means more fuel needed. It may not be a direct relationship as engine efficiency changes with engine load, but essentially, there will be a difference in consumption with aircon on or off.
Gerry
145234
Reply By: Member - Camper (SA) - Thursday, Dec 29, 2005 at 10:35
Thanks to everyone for a good discussion and sorry my reply is a bit behind the post but I've been a tad crook. I got a bit interested in this because a 70 amp alternator flat out is probably using up a Kilowatt when you factor in losses in the belt drive and heat etc. If the air con is pulling 3-5 Kw and a motor is only about 35% efficient I got to wondering how much fuel goes on accessories.
Camper
145864
