NISSAN GU AIR SUSPENSION
Submitted: Monday, Dec 26, 2005 at 10:41
ThreadID: 29168 Views:2166 Replies:4 FollowUps:2
Has anyone converted their truck to rear airbags,not polyair and the like, but full aibags similar to trucks and the new Range Rovers?
Any information would be appreciated.
Reply By: Member - 'Lucy' - Monday, Dec 26, 2005 at 11:36
Yes! A guy called Steve Hobbs who worked at PRO-COMP 4x4 did just that and used to run it on the road and in winch competitions.
From memory it had on board controllers etc.
He has sold it now, and changed employment due to family reasons.
However if you ring PRO-COMP on 03 9705 6677 and talk to either Henry or Richard, they will be able to point you in the right direction.
You might have to wait until after the festive season to contact them. Not sure of
their closure dates over X-mas/New Year.
Ken Robinson
AnswerID: 145591
Follow Up By: Truckster (Vic) - Monday, Dec 26, 2005 at 12:42
yea he had it in the outback challenge and had heaps of problems with it.
theres also a dude on Outerlimits that did it on a GU comp truck, also ended up throwing it to crap.
FollowupID: 399127
Reply By: Member - Duncs - Monday, Dec 26, 2005 at 14:17
I met a guy in Ceduna who had done it to the rear of his GQ.
His prime reason was to allow for ease of loading/unloading his traytop camper. It worked great from what I could see and he was very happy. He had it done in Bendigo or Ballarat I think.
I think he was a member of Wanderers 4wd club. If I can find more details I will let you know.
Duncs
AnswerID: 145601
Reply By: kesh - Monday, Dec 26, 2005 at 20:11
I assume you are referring to a coil rear, not leaf? And you want to replace the coils, not fit something inside (which wears through and goes Phutt.)
From observation, the Polyair bags meant for leaf springs (have them on my 75 tray) are identical to the ones used on buses, B double etc. They are a bellows system, centre reinforced to maintain bag alignment, pressure to 100psi.
To me, they would be the DG's for coil replacement.
kesh
AnswerID: 145633
Follow Up By: kesh - Tuesday, Dec 27, 2005 at 07:54
Should have said identical in appearance, certainly not in size!
kesh
FollowupID: 399184
Reply By: fourstall2000 - Tuesday, Dec 27, 2005 at 08:06
Thanks guys much appreciated.
As Pro comp is close to me I will call in and enquire after new year.
AnswerID: 145673
