Tyres for Landcruiser
Submitted: Wednesday, Jan 04, 2006 at 22:58
almepal
Need some tyres for 100 series cruiser. Any suggestions? Thanks
Reply By: ShnogDog - Wednesday, Jan 04, 2006 at 23:07
almepal,
what type of driving/conditions would you mainly use the cruiser for. This will determine the best type of tyre. Mostly, a good All terrain tyre like Cooper ATR or BF Goodrich will serve you
well. There are plenty of good tyres around. Maybe if you let the
forum know a bit more about your typical use and driving conditions, you will help narrow the field and get some good feedback.
Mark
146476
Follow Up By: almepal - Thursday, Jan 05, 2006 at 12:47
Thanks for the replies - We are pulling a 20' caravan. Most use will be on road with some beach and bush track driving.
400037
Reply By: Bob Y. - Qld - Thursday, Jan 05, 2006 at 07:00
almepal,
BFG AT's. Have used these for nearly 180K clicks on an 80 series, with no blow-outs. Have had a few flats, but give reasonable wear.
All depends on size, intended use etc.
Hooroo...
146494
Follow Up By: Member - Phil G (SA) - Thursday, Jan 05, 2006 at 11:22
Hi Bob,
Pity they don't make them like that anymore. I take it yours were not the KO's. I've got a set of KO's that have done 70k and still have 6mm left, but they were only used on bitumen by the previous owner.
400018
Reply By: OMN - Thursday, Jan 05, 2006 at 09:30
Thats very impressive wear from a set of BFG's, hope i get that far on
mine :):)
Mark
146513
Reply By: OzRoamer - Thursday, Jan 05, 2006 at 09:39
I been using BFG Muds since 2002. Firstly on a Prado and now on a 2004 100 Series GXL.
A mate of
mine ownes a tyre outlet and also does a heap of Offroad and 4WD Rally events and recommended that I go with 255/85/16R which would give me a bit more height and not to much float?
I have not done as much offroad this year due to the business and may look at the AT's next time but I can't fault the BFG Muds. I would stay with BFG either way.
Hope this helps.
146517
