Electric Toaster.......new 2007 model proposed
Submitted: Wednesday, Jan 11, 2006 at 17:58
ThreadID: 29574 Views:2816 Replies:9 FollowUps:14
I don't profess to know much about toasters, but I've just been made aware that breville have a new one about to be released. Apparently it'll have 2 plug holes (just like my engel fridge)....one for 12v and the other for 240v. There is also a Butane canister option like those little cheap (but gr8) stoves that a lot of people use.
It's gunna take up to 6 bits of bread at a time, and to conserve power you can choose how many of the 6 pairs of elements you want to have ON at any time.
A lot of people worry about element style gadgets being used on 12 volts, but this one is VERY efficient and will use less power than your 1a/h flouro light.
When not in use it can be folded down to a much smaller size.
Now I know some of you might be a bit sceptical, but I read this in the March 2006 issue of 4WD Monthly, so it MUST be true!!! ;-))
Reply By: Member - Phil G (SA) - Wednesday, Jan 11, 2006 at 18:01
Hi Roachie,
Wouldn't it be cheaper to buy a $20 Tiffany toaster from Cunno's and use two 1500watt inverters to run it from three 100Ah AGM's? Could use the same setup to run the frypan :-)))
phil
AnswerID: 147831
Reply By: David from Engine Saver Low Water Alarms - Wednesday, Jan 11, 2006 at 18:13
What size shoelaces does it take?
AnswerID: 147832
Follow Up By: gramps - Wednesday, Jan 11, 2006 at 18:16
Aaaaah ! Another one. David, you should know better :)
FollowupID: 401144
Follow Up By: David from Engine Saver Low Water Alarms - Wednesday, Jan 11, 2006 at 18:20
Sorry Gramps! :-)
Couldn't help myself !
FollowupID: 401147
Follow Up By: Des Lexic - Wednesday, Jan 11, 2006 at 19:13
15" white broad ones
FollowupID: 401153
Follow Up By: David from Engine Saver Low Water Alarms - Wednesday, Jan 11, 2006 at 19:46
Is that 15" tied or untied? :-)
FollowupID: 401156
Follow Up By: Bonz (Vic) - Wednesday, Jan 11, 2006 at 23:09
UNtied, everyone knows that shoelaces are measured untied, sheesh what'd you learn at reform school?
FollowupID: 401222
Follow Up By: David from Engine Saver Low Water Alarms - Wednesday, Jan 11, 2006 at 23:28
Sorry for the slip up Bonz,
They didn't allow us laces at reform school.
Thought you would've known that :)
FollowupID: 401228
Follow Up By: Des Lexic - Wednesday, Jan 11, 2006 at 23:31
Yes I can positively confirm it's untied.
I'm not getting into an arguement on Knots.
FollowupID: 401231
Follow Up By: David from Engine Saver Low Water Alarms - Wednesday, Jan 11, 2006 at 23:36
UNtied ok! Thanks Des.
I am glad we got that one straightened out!
FollowupID: 401234
Follow Up By: Bonz (Vic) - Thursday, Jan 12, 2006 at 22:21
They wouldnt allow us to have guns at our school but we still LEARNED about them, don't know what education is coming to these daze.
FollowupID: 401430
Reply By: ACDC - Wednesday, Jan 11, 2006 at 19:05
I believe there's a new cruiser coming out later in the year with one in the centre console so you can have brekky on the way to work!!
But don't tell anyone!!!
AnswerID: 147842
Reply By: Member - Willie , Epping .Syd. - Wednesday, Jan 11, 2006 at 19:22
I read in the April issue that there is a new 12 volt microwave snap freezer that works by putting an inverter in the line before the microwave thereby reversing the action of the microwaves and sending the atoms to sleep instead of exciting them .
Also in this issue is the article dealing with the revolutionary off peak gas heater . Technology just keeps making life easier and easier for us .
Cheers ,
Willie .
AnswerID: 147850
Reply By: V8Diesel - Wednesday, Jan 11, 2006 at 19:28
Not entirely true Roachie, in the latest issue of 4x4 Monthly (May 2006) they printed an apology saying it was all a big mistake, it uses a 12V Hella plug - not the 2 pin Engel as originally quoted.
Either way, does sound like a very handy bit of kit. An adaptor is easy enough to make.
BTW, will it do crumpets?
AnswerID: 147853
Reply By: Brew69(SA) - Wednesday, Jan 11, 2006 at 20:15
I am waiting for the Nissan version, unless Waeco bring one out first.
AnswerID: 147868
Follow Up By: Des Lexic - Wednesday, Jan 11, 2006 at 23:33
With the Nissan version Brew, you have to be very careful cos it will overheat.
FollowupID: 401232
Reply By: Lone Wolf - Wednesday, Jan 11, 2006 at 21:05
"A lot of people worry about element style gadgets being used on 12 volts, but this one is VERY efficient and will use less power than your 1a/h flouro light. "
This would then equate to what... about 10 - 12 watts of heating power, which is 41 BTU. Now, my Coleman stove runs at 10000 BTU, and I still can watch my toast cook slowly.... can't quite work out the math I'm afraid.
Wolfie
AnswerID: 147884
Follow Up By: Member - Roachie (SA) - Wednesday, Jan 11, 2006 at 21:15
Wolfie, I knew I could rely on you to throw in a curly one at this point. I'm afraid you've now opened up a can of worms, so before speculation starts, I guess I should explain.
This machine is not just an "ordinary" toaster. It contains special components developed by NASA for the space program. Indeed, it is the main driver they are going to use in the new space craft that will be launched soon and will take people to Mars in 3 hours.
I believe the technical term is "fuel cell" and from what I can gather it is something like how we currently use a 12v battery via an inverter to run a air conditioner.....well this has got an inbuilt inverter on a smaller scale. In fact they're already working on phase 2 of the project which will see this same toaster (except it will be limited to 2 slices at this stage), operated by using 2 NiMH "AA" batteries which will be good for up to 10 slices of toast (medium done).
Now, when is that LPG-powered generator sposed to on the market?
FollowupID: 401178
Follow Up By: Member - Ozdyssey (QLD) - Wednesday, Jan 11, 2006 at 21:51
read in the June '06 issue the LPG will be reviewed in the coming July issue
FollowupID: 401193
Follow Up By: Mike DiD - Wednesday, Jan 11, 2006 at 23:19
Roachie
Do you sell Hiclones as your day job ?
Mike
FollowupID: 401226
Reply By: GOB & denny vic member - Wednesday, Jan 11, 2006 at 21:42
goodday bill
will it also have an inbuilt hairdrier for while we are travelling to cut down on all the junk we have to take on our trips
lololol
steve
AnswerID: 147894
Follow Up By: Member - Roachie (SA) - Wednesday, Jan 11, 2006 at 21:44
Steve,
Sorry, you're gunna have to wait for phase 3 for the hairdryer, could be end of next year by all acounts. ;-((
FollowupID: 401191
Reply By: Bonz (Vic) - Wednesday, Jan 11, 2006 at 23:11
Does it come with HID's?
AnswerID: 147917
