waeco cf-40 operating/instructions
Submitted: Thursday, Jan 12, 2006 at 21:53
ThreadID: 29633 Views:6915 Replies:3 FollowUps:0
i have just bought a waeco cf-40 ac fridge and cover for a good price. but there wasnt any instructions with it . (not the one with the digital display)can anybody help?
Reply By: Member - John - Thursday, Jan 12, 2006 at 22:05
try waeco direct?
John and Jan
AnswerID: 148173
Reply By: Haza - Thursday, Jan 12, 2006 at 22:09
15-30 degrees outside I have 2-3 green lights on the top bar for fridge operation. Turbo is for faster cooling as in placeing new/warm food/drink into the unit. Down where the power plugs is there is a swicth with low/med/high this is your 12volt battery cutoff, low is the batt will drained to a lower voltage, not sure of the spec. I run off a second batt so mines set to low. If running off the car batt have it set to med or high.There is also a emgerency swicth which will make the compressor run all the time, it bypasses the contol panel, it will act as a freezer under fault condition when activated.
AnswerID: 148176
Reply By: swagman - Thursday, Jan 12, 2006 at 22:17
thanks very much for the info
AnswerID: 148181
