engle fridge 24volts to 12volts?????
Submitted: Tuesday, Jan 17, 2006 at 16:07
ThreadID: 29791 Views:2883 Replies:9 FollowUps:1
Hi today I got an old fridge from an import bus from japan but it runs on 24volts. I know it is a long shot but I wonder if you can change 24volts to 12volts?? If not, I know you can put 2 batterys it series to get 24volts but my truck runs on 12volts so I cant charge them while moving. It is a great old(15years) fridge. Any ideas????? Thanks Deano.
Reply By: Member - Geoff M (Newcastle) - Tuesday, Jan 17, 2006 at 16:26
Might find some answers here,
Post Id 29632
Geoff.
Geoff,
AnswerID: 149160
Reply By: Russel & Mary - Tuesday, Jan 17, 2006 at 16:40
type in redarc and search. Click on REDARC SUPPLY POWER CONVERSIONS......
Click PRODUCTS L-Z , then VOLTAGE BOOSTER. Rus.
AnswerID: 149163
Follow Up By: Russel & Mary - Tuesday, Jan 17, 2006 at 16:45
deano8it, click on VOLTAGE BOOSTER ,not the pop up window alongside of it once you've placed the curser on it. Rus.
FollowupID: 402315
Reply By: Utemad - Tuesday, Jan 17, 2006 at 17:30
Are you sure it only runs on 24v? Current Engels run on 12v or 24v.
AnswerID: 149178
Reply By: Eric Experience. - Tuesday, Jan 17, 2006 at 21:26
deano8it
I am in the market for a 24 volt fridge, if you can give more details we may be able to both win. Eric.
AnswerID: 149226
Reply By: deano8it - Wednesday, Jan 18, 2006 at 09:21
Hi eric, will speek to the bloke on sat, I will let you know. It looks like I can get a 12v to 24volt for around 70dollars. max of 2.9amps. Do you think this is enough amps? Thanks deano
AnswerID: 149326
Reply By: Sam from Weipa Auto Electrics - Wednesday, Jan 18, 2006 at 16:57
All depends on what size fridge it is what the current _Affordable_Storage_Drawers.aspx etc is there anything written on the fridge???
AnswerID: 149421
Reply By: deano8it - Wednesday, Jan 18, 2006 at 17:02
Hi sam, It has jap writing all over it. It said 24v input at the back. Tryed it on 12v but it ran slow. any ideas Thaqnks Deano
AnswerID: 149423
Reply By: techie - Thursday, Jan 19, 2006 at 03:00
is this a compressor fridge or a thermo fridge?
was thinking of making an inverter 12 -> 24v @ 6 Amps.
still playing with the idea. Hard part is the transformer.
Techie.
AnswerID: 149539
Reply By: Sam from Weipa Auto Electrics - Thursday, Jan 19, 2006 at 09:36
You might have to get it translated but I think they would be rated at about have the current rating of the fridge the same size in 12v so if you get that info you can get a 12-24 power supply to suit or else take it to an engel repairer and get the motor change to a 12v one it might not be that expensive if he has a secondhand one kicking around.
AnswerID: 149569
