adelaide 2 innaminka
Submitted: Wednesday, Jan 15, 2003 at 23:08
dc
im travelling toinnaminka from
adelaide and was wondering if via
lyndhurst or via
broken hill was the easier route.can someone advise me on road cond and
fuel consumption.we will be travelling in mid march in one car .also how far is it thru sturt nat
park and what conditions driving wise can i expect ,"is it puncture country and would you class it aeasy drive or harder trip. ps:how far via each route? cheers dc.
Reply By: Mike - Thursday, Jan 16, 2003 at 10:18
dc, via
Lyndhurst is definately a lot shorter and is not all that hard. the road is quite good, especially if you use the new track, via Moomba. We usually stop at
Copley and Blanchwater
Ruins on the run just so that we can take our time. The roads are not generally tyre destroyers, but I would always take 2 srares when travelling in this type of area. Last time we travelled to the Cooper via NSW, we went via the Warri
Warri gate up through Qld. This trip was over very rough roads and was quite hard on the vehicles. Either way, you will have a ball, travel through some marvellous country and end up in heaven (aka
Cooper Creek)
Happy
trails,Mike.
11374
Reply By: Member - Mike - Thursday, Jan 16, 2003 at 13:12
Fortunately do this run reasonably often - is my backyard!
National Parks have
good campsite on Strez Track at
Montecollina Bore set within dunes - favourite spot of
mine.
Concur with remartks re Cooper. From Innanmincka try
Bore Track to Boollards
Lagoon, ring first and will cost $10. Takes you close to Camerons Corner. (
Fuel avbl). Then cross border into NSW and Sturts NP. Good
camping enroute and nice site outside Tiboburra nb
water restrictions there at moment so carry your requirements.
Fuel avbl. return via Depot Glenn and Milaparinka (pub upgraded),
Broken Hill is worth doing.
Re
fuel. I drive GQ RB30 petrol and can get from
Lyndhurst to "Minka on main
tank, ditto return legss as outlined(I do carry auxilary
tank but not required. NO
FUEL at Moomba. By pass track from Strez. crossing to "Minka ie Old Strez Track easy and interesting.
I hope that whets the appetite! Warning March can be hot and mind 40s.
Mike
11378
Reply By: Darian - Thursday, Jan 16, 2003 at 14:38
DC - to support the above - we love it up there - both
routes to the Cooper are "easy" in off road terms - surfaces are really good dirt BUT with the provisos: 1. Rain changes everything 2. Your are suitably equipped (eg "town tyres" will probably suffer on the lower two thirds of the Strz - those 2 inch stones can be a pain in the wallet ! And yes re Mike and the temperature - I went up with a group in LATE April 2002 - around 35 everyday - was close to 40 out at
the Dig Tree with a north wind......can be very tiresome, and as lovely as the Cooper is, it probably won't be fit for swimming in ! Conversely, you might get rained in for a week, and be shivering, or the weather could be delightful......(most of we regulars have experienced the lot) ....but you have to go.......it is always worth it.
dp
11386
Reply By: chapo - Thursday, Jan 16, 2003 at 20:52
G'day dc.
We have just returned from
Innamincka , the best route is by far through
Lyndhurst and up the
Strzelecki track. Dont go via Moomba ,the road is too rocky.Go via Merty Merty ,turn left and follow the
Strzelecki track. When it meets up with the Dillon Highway(Moomba rd) turn right for a couple of hundred yards then laft again onto the track which will take you all the way to
Innamincka.If you take the Dillon highway you are in for the roughest 50 klm you'll ever drive.Dont believe all the rubbish about the track being 4wd only.It is a much better road than the main drag.
The
Cooper creek is OK for swimming and the Coopers on tap at the pub is magnificent.Cullyamarra
waterhole is a great
camping site but wood is scarce,best to bring some.Fishing is good but heaps of turtles.
11405
Reply By: Phil G - Thursday, Jan 16, 2003 at 22:08
dc,
I usually suggest that you go up one way and come back the other.
Broken Hill,
Tibooburra and spend a couple of days checking out Poole's Marker,
depot glen,
milparinka, and the tracks in Sturt Nat
Park, then off to Cameron's Corner (refuel) and take the
bore track to
Innamincka. Can be a little easy to lose your way on the
bore track.
Cullyamurra Waterhole should still be good even if the
water level is low.
I was last there 6 months ago and the level in Coopers was lowish, but Coongie Lakes was fullish.
You could come back via the old Strezlecki - nicer drive than Moomba, and if you still have the time, turn off and come down thru the
Flinders Ranges. We camped at Chambers Gorge last time.
Best way to prevent punctures is to run lowish pressures in your tyres (say 24psi), keep your speed below 80kph and don't overload the vehicle. If travelling alone, I take an extra spare casing.
Its an easy trip. I did all that in a Corolla in 1978!
Phil G
Adelaide
11412
Follow Up By: Chapo - Friday, Jan 17, 2003 at 02:49
Hey PHIL,isn't Chambers Gorge great.We camped there only a month ago, we were the only ones there,
well us and the wallabies.
Cullyamurra waterhole had plenty of
water in her ,the temp hit 48 in the shade but it was beautiful in the
creek.
6346
Follow Up By: Phil G - Friday, Jan 17, 2003 at 12:52
Chapo,
Yeah, we enjoyed it too. As
well as the wallabies, there were patches of Desert Pea and the magnificent
red cliffs at sunset. Only 8km off the main drag from memory.
About 10 years ago we took the family to Cullyamurra and camped for the week after Xmas. Everyone said we were crazy. Hut we had the place totally to ourselves, spent the mornings in the
water in the shade of the gums, spent the afternoons in the pub and had no problems with the 40 degree heat. Sounds like you had the same!
6368
Follow Up By: Chapo - Friday, Jan 17, 2003 at 18:49
G'day Phil.
Gee mate sounds like we could have been on the same holiday.Thats exactly what we did.Went for walk early in the mornings,then swam to cool off and then hit the pub for a few icy cold Coopers and the best meat pies I've ever tasted.
We teamed up with a
young family we met at
Lyndhurst and they travelled with us for a week.They had two
young kids who were feeling the heat a bit, so big Des in the pub hired a couple of videos from the trading post, put them on for the kids and we spent all arvo in the air conditioned comfort of the pub.Good man that Des!
6379
