Esky Catch Repair
Submitted: Sunday, Jan 22, 2006 at 22:20
Member - John A (SA)
Hi Forumites
Does any one know how to replace the retaining tag that tucks in behind the lip of the inner liner on "Esky" & "Coleman" eskies?
These tags have pulled out when the lads used the esky as a cricket wicket!
The only way I can see that it might be possible is to drill out the plastic pop-rivets / grommets. One would then have to obtain a supply of these rivets / grommets (from where?)
Any help you can provide would be appreciated.
John Adamson
Reply By: Nudenut - Monday, Jan 23, 2006 at 07:47
i know the drian assembly are available as spare part....maybe too the parts you require?...give them a ring to see if available or Christies
camping on lower NE rd or any other good store.
150249
Follow Up By: Member - John A (SA) - Monday, Jan 23, 2006 at 08:53
Thanks NN
I dont believe I explained myself too
The catch assembly itself isn't broken. Its only that the plastic backing needs reinserting back behind the lip of the liner on the outside where it meets the outer casing.
The plastic seems too stiff to bend & reinsert between the inner liner & the outer body.
403687
Reply By: madCrow - Monday, Jan 23, 2006 at 14:55
Hi John,
I hope this is perhaps the answer to the last question re: grommets at least.
I my self was after some speed nuts & I went to Burson's Auto Parts (their like repco), when looking at the "chapion' nuts & bolts stand I saw grommets of different sizes were available. Hope this helps.
madCrow
......(0_o)
\\\\(-><-)///// The large shy bunny with a hair cut, hides in the grass.
The sound of a truck backfiring makes him sit up straight!
150309
Follow Up By: madCrow - Monday, Jan 23, 2006 at 15:00
Ahh that's not chapion it's "Champion".......
the bunny's mistake, not
mine (like not!)
......(0_o)
naughty boy!
403762
