Internal LED Lights
Submitted: Monday, Jan 30, 2006 at 16:29
Taff
To reduce the drain on battery in my camper I wanted to know whether anyone had succeeded in putting in internal LED lights in vans or campers? (Instead of the ones that come as standard when purchased)
I have Jayco Eagle (2004 model) with a deep cycle battery added to it
I do not want running lights (ie brake / indicators etc) which I know can be obtained
Reply By: Notso - Monday, Jan 30, 2006 at 16:33
Reply By: flappa - Monday, Jan 30, 2006 at 16:37
I use LED lights on my CT.
One they a I made was the regular halogen downlight , fitted with a 18 LED insert. The Original light drew about 3 amps . . this LED draws less then 1.
151831
Reply By: Mike DiD - Monday, Jan 30, 2006 at 17:47
LED lights are not much more efficient than globes. The most light output for a set amount of input power is from Compact Flourescent lamps .
http://www.netl.doe.gov/ssl/faqs.htm
You can get 12volt
Nelson Compact Flourescent lamps from SOME Bunnings stores and from ww.jaycar.com.au (10 and 20 watt). Do not confuse these with standard 12 volt fittings using standard flourescent tubes
If you want low-power lighting (less than 1 watt) then LEDs are certainly more convenient than any other form.
Mike
151859
Reply By: Member -Dodger - Monday, Jan 30, 2006 at 17:53
In the LED
shop see Previous Post there are baynet type led's available as
well as festoon bulbs. Get the biggest you can.
I put a festoon type on the rear door (inside) of my Patrol and it lights up the rear really
well, great for seeing in those drawers.
151860
