car stalling
Submitted: Thursday, Feb 02, 2006 at 09:57
Hihihilux
We have a 95 hilux that keeps stopping every time we put the accelerator down to go fast. The car hasn't been used for a long while and we thought maybe the diesel has gone off, but maybe the petrol filter is clogged.
Does anyone have any ideas??
Reply By: Footloose - Thursday, Feb 02, 2006 at 10:45
"the diesel has gone off, but maybe the petrol filter is clogged."...weel, if its a diesel it won't have a petrol filter, will it ? :))
However it will have a
fuel filter which could be blocked. You may also have the diesel "bug" in your system, which will clog up your filter.
152477
Follow Up By: Member - Luxoluk - Thursday, Feb 02, 2006 at 11:38
Petrol, gas,
fuel....I think we understand what "Hihihilux" was referring to??
406209
Follow Up By: Footloose - Thursday, Feb 02, 2006 at 12:09
And your advice to him is ???????
406217
Follow Up By: Member - Luxoluk - Thursday, Feb 02, 2006 at 19:00
I reckon he was already on the way...identify possible causes and seek to eliminate until solution established. Of course there is always a mechanic to consult if it all gets too hard. Cheers
406318
Follow Up By: Twinkles - Thursday, Feb 02, 2006 at 22:54
I had a problem with my first Hilux, an '84 2.2 diesel. When I put my foot down it would surge or stall. Rang dealers, mechanics and Toyota. Finally got an answer, which was correct, from a diesel mechanic in
Melbourne. The metal tube from the top of the
fuel tank which extended to the bottom of the
tank and had a simple filter on the bottom had developed a crack at the top and movement caused it to flex and open or close the crack, so sometimes sucking air.
406360
Reply By: Gerhardp1 - Thursday, Feb 02, 2006 at 14:26
Your Fitch is blocked.
152514
Follow Up By: nickoff - Thursday, Feb 02, 2006 at 14:42
No, no, no, you've got it wrong. The hiclone is in backwards and instead of sucking harder when you put you foot down, it blows back up and stalls the engine.
406247
Reply By: Gerhardp1 - Thursday, Feb 02, 2006 at 14:48
Oh p bleep , I've been found out.
152516
Reply By: Mad Dog (Australia) - Thursday, Feb 02, 2006 at 15:38
check your air filter, could be blocked with a birds nest or critter crap.
152532
