UHF To Fit
Submitted: Saturday, Feb 04, 2006 at 04:51
4Harves
Can any help with suggestions of a good UHF to fit in a Nissan Navara dash.
Reply By: Member - toohey - Saturday, Feb 04, 2006 at 06:22
GME TX3200
152864
Follow Up By: Pluto - Saturday, Feb 04, 2006 at 07:56
I would agree. Either the TX3200, 3400 or any small format tranceiver.
I mounted my Tx3200 to my Patrol below the dash, on the panel that meets the central hump, so that it sits between the gear sticks and the dash. It required a wooden spacer, but ended up looking like an integral part of the dash. It also didn't require an external speaker as the inbuilt faced into the cabin.
406669
Follow Up By: Member - toohey - Saturday, Feb 04, 2006 at 11:34
TX3200
fits in pocket above the radio
cheers toohey
406720
Reply By: MattyM - Saturday, Feb 04, 2006 at 08:48
You can use any UHF with a DIN mounting kit. If you pull out the radio & the that little storage pocket you can fit the UHF in the radio bracket.
I fitted a TX3200 with the DIN mounting kit to my Navara & a mate used a TX4400 in the same spot. It sits in the dash properly & looks like it was meant to be there.
Matty
152877
Reply By: roofscooter2 - Saturday, Feb 04, 2006 at 09:31
gme 3600 split system works
well also ( did in my f250) regards ,bob.
152886
Follow Up By: roofscooter2 - Saturday, Feb 04, 2006 at 21:00
sorry misleading info, should be gme 3400 split system,cheers bob.
406875
