Landcruiser electric.........
Submitted: Sunday, Feb 19, 2006 at 18:57
Member - Reiner G (QLD) 4124
My Landcruiser is a HJZ75 Trayback (1996)and yesterday I had no lights on the dash and no ignition at all. It looked like a flat Battery. After checking the battery was full so I did the usual...fuses all good ignition lock good still no 12 volt.
When I followed the cables I found a little black box( 3hrs later) maybe 1 inch long with a white and a black cabel going in and white and blue coming out going to the fuseblock. That box was on the battery side in the motorcompartment hanging of some cable. All it has inside is two bolt and nut connections which had rust inside. Some WD40 and a wire brush and it all came to light again. I'm still wondering what that littel black thing is for and I thought somebody in here will know for sure.
Reiner
Reply By: gen3rules - Sunday, Feb 19, 2006 at 19:04
It is just a terminal block to join the fusible links to the loom
155878
Follow Up By: Member - Reiner G (QLD) 4124 - Sunday, Feb 19, 2006 at 20:24
I just go to Repco and get a new terminal block? the one in my Cruiser looks pretty sad.
Reiner
409859
