Thrust Brg change out - 4 runner
Submitted: Tuesday, Feb 28, 2006 at 08:59
Boc1971
well amongst my usual bad luck -- my thrust bearing has now gone on my 91 4runner ( sr5 v6 ) -- when clutch is pressed makes a terrible grinding noise and can feel it thought the peddle ...
anyway -- i will change this myself --- anything i should look for ?? anyone have an online manual ? these gear boxes are sealed to outside
water and dirty right ?? rather than the simple plates on standard cars?
i have done my van clutch in about 3 hours .... ( toyota hiace ) but suspect this will take MUCH longer ......
any suggestions guys ?
Frank
Reply By: Footloose - Tuesday, Feb 28, 2006 at 09:58
Frank, no idea about your vehicle, but I have changed a series 60 clutch by myself. And I'd never seen a clutch before :)
The trick is to support the gearbox and engine properly. The two have to come apart.
Mine came apart by using a system of ropes and a sit on mower !
I wouldnt even attempt it these days. MUCH easier to save up the $$ and pay through the nose.
157476
Reply By: Member - Stephen M (NSW) - Tuesday, Feb 28, 2006 at 10:22
Hi there boc1971, where are you located at. ? Regards Steve M
157479
Reply By: BenSpoon - Tuesday, Feb 28, 2006 at 17:06
If you need to, a broom stick and gaffer tape make a very handy "spigot realignment tool"
157577
