Mildew in a Howling Moon
Submitted: Tuesday, Mar 07, 2006 at 21:13
ThreadID: 31521 Views:2118 Replies:3 FollowUps:2
Hi,is there a way to get mildew out of canvas it is not real bad only in a few areas the cover leaking while in Dawin,they replaced the mattress and will replaced the top if I pay 500.00 plus the freight.Regard Bat.
Reply By: Member - Shane M (WA) - Tuesday, Mar 07, 2006 at 22:36
I can recommend something that definatley works, it's called Mildew Cleaner & Stain Remover by Rule/Sudbury.
The above works great on canvas even coloured canvas, we did a complete camper trailer that was extremely bad/covered in mildew and it removed every trace of it. Just make sure you read the directions and you can't go wrong.
AnswerID: 159222
Follow Up By: Member - DOZER- Tuesday, Mar 07, 2006 at 23:06
Another thing to try is Lanolin spray.....takes off mildew from the bathroom roof no probs...most bearing places sell it
Andrew
FollowupID: 413765
Reply By: Member - Mike H (VIC) - Wednesday, Mar 08, 2006 at 02:36
Hi Bat,
I diluted Pine-Clean or Detol with water. Set up the tent and brush it all over, inside and out, then let sit and dry. Best to let the tent stand for a few days. Check and repeat if necessary.
Worked for me.
Mike
AnswerID: 159250
Follow Up By: GEG - Wednesday, Mar 08, 2006 at 08:19
Yep did mine the same way...still smells musky when I first put it up...many times later
FollowupID: 413800
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Mar 08, 2006 at 02:48
my swag has mildew instructions I am not at home but i am sure it says just brush it off and for more intrusive attacks use dilute bleach and I think it mentions resealing the canvas if a fairly large area is treated
AnswerID: 159252
