dirty coolant
Submitted: Friday, Jan 31, 2003 at 19:45
Jono
sorry for this dumb question, but here goes...
1) What is it that makes the coolant get dirty?
2) Given that coolant does get dirty, how long should it usually take to get dirty?
3) What is the go with "long life coolants"? is it actually any different? and is it worth the extra cost?
Jono
Reply By: Member - Chris - Friday, Jan 31, 2003 at 19:56
Not that I'm the expert Jono, but the coolant breaks down chemically and becomes acidic that eats into your alloy bits of the engine and radiator. Generally, the white rubbish that coats your thermostat and inside of your radiator is rubbish thats been eroded away.
I try and change
mine annually, but often that goes our to every 2 years or so.
chris
12277
Reply By: Truckster - Friday, Jan 31, 2003 at 20:03
Depending on your engines and cooling systems age, material of makeup etc... Also if your cars been boiling/getting hot etc..
Most of the discolouration is rust!
But I change it every year, its only ~$20!
12280
Reply By: bruce.h - Friday, Jan 31, 2003 at 21:18
Gday Jono
Dont quote me on this becauce im no expert either but some where deepin the vault i seem to remember being told that it is like a ware indercator that when it goes dark it is a
sign that it is time to change it how true that is i dont know but from experance i can tellyou if you run an ali head make sure you use not just coolant but the correct coolant for your motor , i made the mistake of using
water in stead think i would save money it stuffed the hesd in no time flat very expensive mistake,thats when i found that there are diferent coolants for different motors . hope this is of some help but dont take the bit about dis colouration as gospel as my brain is full of tit bits some true others not so sure on
Regards Bruce
12289
Reply By: Peter - Friday, Feb 07, 2003 at 18:41
I would say that cooling system servicing is almost as important as changing your oil.
And it is very important you use the correct coolant.
I use Natra Coolant it is expensive $13.50 a litre and need 50% mix for a diesel but get 3 years out of it and I test it all the time with some castrol test stips that are about $7.00 for container.
12670
Reply By: David - Monday, Feb 10, 2003 at 17:22
Have a 12 year old GQ Patrol Diesel (no alloy head etc.) and have changed the coolant ATLEAST twice! (If that!)
Have never had a cooling or corrosion problem and it's clean in the radiator etc.
12816
