what battery should i use
Submitted: Monday, Mar 20, 2006 at 20:31
ThreadID: 31954 Views:2880 Replies:7 FollowUps:2
what battery is best to use for a duel battery set up on a nissan patrol 2.8 td, I will be running the eva kool 60ltr fridge/freezer and also a glind hot water shower on the duel battery.
Any help would be much appreciated thanks
Reply By: Notso - Monday, Mar 20, 2006 at 20:34
Plenty of advice around on this site, Basically two choices, go for one the same as the main battery, or put in a deep cycle.
Arguments for and against you will find if you do a search.
AnswerID: 161754
Reply By: scottp - Monday, Mar 20, 2006 at 20:35
Fullriver AGM dc searies
AnswerID: 161755
Reply By: Alloy c/t - Monday, Mar 20, 2006 at 20:48
10,482 references for dual battery in SEARCH ,have a LOOK.
AnswerID: 161762
Reply By: Member - Doug T (QLD) - Monday, Mar 20, 2006 at 21:12
I reackon these Optima's are worth a look.I am using one as the accessories Battery and it's going ok so far
optima
AnswerID: 161766
Reply By: Member - Ozdyssey (QLD) - Monday, Mar 20, 2006 at 21:55
Gel or AGM
run our evakool 60 off 120amphr AGM's (fullriver)- more tolerant in general use especially with charging etc.
streams of info in the archives
AnswerID: 161787
Reply By: Mainey (WA) - Monday, Mar 20, 2006 at 23:13
hobo, I'm the most biased person to reply L0L, get an "AGM" in Deep Cycle build, not cyclic (I distribute both types)
Why not contact EvaKool or your local competant Auto Elect and ask them?
You will get so many 'personal' opinions here you may be confused, not all of them can be correct, or even wrong, you can even use a Cranking battery to run a fridge.
But if you want real value for money and superior battery performance you can't get better than a Deep Cycle AGM battery.
AnswerID: 161799
Follow Up By: Member - Norm C (QLD) - Monday, Mar 20, 2006 at 23:28
I don't see your trader ad any more Mainey??
FollowupID: 416473
Follow Up By: Mainey (WA) - Tuesday, Mar 21, 2006 at 00:38
Norm,
yes it was moved from the "Private sale" area some time ago however I can't find it now either, things like that happen when you start cutting 30% off the price of Quality AGM's so I will make enquiries and see what has happened.
David E-mailed me and advised me the add was being moved and gave me the new address, it still looked really good and got the same message accross of the huge savings that could be obtained by allowing me to source for you the best price available on quality solar panels, solar regulators and AGM batteries!!!
FollowupID: 416477
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Mar 21, 2006 at 08:48
Hi Hobo
Best to go for a good quality AGM, they charge faster than normal lead acid batteries and have more than twice the service life. I would wire the glind to the main battery. I have seen Evakools go into 'fault' mode if the glind's pump pulls power from the auxillary battery when it is down on power.
Regards Derek.
AnswerID: 161848
