Flojet shower pump
Submitted: Tuesday, Mar 21, 2006 at 12:31
Austravel
Has anyone found a cheaper alternative to the Flojet pump range?? Intend setting up a shower pump under the camper and am sick of replacing the cheap 12 volt shower pumps. The Flojet are good quality but a tad expensive.
Reply By: Member - Tony G (ACT) - Tuesday, Mar 21, 2006 at 12:35
The two that spring to mind are the Flow Jet and the Sure Flow, both around the same price but work
well as a shower pump.
I prefer the Flow jet as I use one on a spray
tank for spot spraying and one for the
water pump on the camper as
well as one for a shower, all work really
161904
Follow Up By: Austravel - Tuesday, Mar 21, 2006 at 17:53
Thanks.
416610
Reply By: flappa - Tuesday, Mar 21, 2006 at 13:04
Yes , there is another.
Cant for the life of me remember the name however, They are available from Camping/Caravan Shows. They have a full range (from the bigger suckers to little ones) , and probably Chinese imports (just a guess). They are priced a heap cheaper then the Flowjet etc alternatives.
I bought a little one for the CT kitchen (only a couple of litres per minute), and cost me $50.
I'll see if I can dig up a name for them.
161911
Follow Up By: flappa - Tuesday, Mar 21, 2006 at 13:14
Ecopumps . . . Thats the mob I think
http://www.ecopump.com.au/index.htm
From Ebay
FL2202
ECOPUMP
12 VDC/ 2.6 litre/ 35psi
WATER PUMP
12 mths warranty
Continual Flow
Used for
water including salt,
water based chemicals and more.
Auto pressure switch on/off
Rubber mounts
Not glued so is servicable
Used for: Spot spraying, Caravan sink supply, showers, Ponds and
water features and much more.
Self priming
small in size approx: 15cm long
Very popular
IN STORE PRICE $96.00
I'm 99.9% sure this is the size I have , but I paid $50 at the Cvan Show.
416556
Follow Up By: Austravel - Tuesday, Mar 21, 2006 at 17:54
Thanks Flappa, you got your's for a bargain.
416611
Reply By: Tim HJ61 (WA) - Tuesday, Mar 21, 2006 at 13:39
There's a lot of cross over products that suit campers/4WD in boating stores.
Whitworths for example have a Rule 800 GPH 12V Bilge Pump for $60, or a Rule 360 GPH 12V Bilge Pump for $27. Either should keep you wet :-)
www.whitworths.com.au
Tim
161916
Thanks never thought of Whitworths.
416612
Reply By: Shaker - Tuesday, Mar 21, 2006 at 16:33
Try this:
Marine and recreational pumps
Smooth Operation
Includes strainer
3 tube adaptors
Self Priming
Silent running
low power draw
runs dry without damage
easy connecting system
Open Flow 3.3 GPM (12.4L/Min)
Volts - 12 VDC
AMPS - 7.5A
pressure setting - 35 psi (0.86 Mpo)
dimensions - 21 x 11 x 11cm
Powered by 12V battery (not included) (utilising red and black metal tip cables)
Recommended Retail Price: $149
DealsDirect Price: only $89 + $9 Shipping (Australia-wide) at this price, you'd better hurry! They're sure to sell out fast!
LINK:
http://www.dealsdirect.com.au/cart.php?m=product_detail&p=978
161951
Thanks, that's a good price.
416609
Follow Up By: Geoff M (Newcastle, NSW) - Tuesday, Mar 21, 2006 at 18:02
I've got one of these, Deals Direct
Works fine,
Geoff.
| Geoff,
416613
Follow Up By: Austravel - Wednesday, Mar 22, 2006 at 09:39
Thanks Geoff,
Can't tell from the specs but I'm guessing it has a pressure switch, does it??? Don't want to put in
water proof switches so definitely want the unit to switch off when tap is turned off.
416834
Follow Up By: Geoff M (Newcastle, NSW) - Wednesday, Mar 22, 2006 at 09:46
Hello Austravel,
Mine has a pressure switch,
Geoff.
| Geoff,
416837
Follow Up By: Austravel - Wednesday, Mar 22, 2006 at 09:54
Thanks Geoff, just went ahead and brought one.
416841
Reply By: Member - Ivan (ACT) - Tuesday, Mar 21, 2006 at 20:16
Watch the flow rate - I have a SurFlow which is 12 lpm - I wouldn't want anything less..
Some of the above are also 12 lpm at a cheaper price, so may be a good buy..
Some of them are only 4lpm - beware unless you only have a small back to wash ;-)
162026
Thanks Ivan, was wondering the same thing about min flow rates.
416835
Follow Up By: flappa - Wednesday, Mar 22, 2006 at 10:07
Thats true.
I have a seperate Flowjet shower pump . . . This small one is purely for kitchen duties , not shower duties.
416848
