Landy Owners Help!!!
Submitted: Friday, Mar 31, 2006 at 21:59
Axle
How do you support the roof linning on the defenders, without having to hold your head up high?
Cheers Axle.
Reply By: Bilbo - Saturday, Apr 01, 2006 at 00:27
Use several green saplings, cut to length. It's a bit primitive but it will match everything else on the Defender ;)
Bilbo
164188
Follow Up By: Axle - Saturday, Apr 01, 2006 at 09:32
YEAH .... Right !!??
419110
Follow Up By: hz75 - Sunday, Apr 02, 2006 at 19:06
i like that!!!!!
419294
Reply By: disco driver - Saturday, Apr 01, 2006 at 00:55
Hi Axle,
Sounds like the Defender has the same problem as some of the earlier Rangies had.
On my 89 Rangie I used a pressure pak fabric adhesive after easing the lining away from the door frame tops to gain access between the roof and the lining.
Followed the instructions on the can re tack time etc and used a 250mm paint roller to smooth the lining back into place. Had to be very careful not to stretch the lining too much and create wrinkles.Started from the middle of the roof and worked out to the edges.
Took about 2.5 hrs but was a reasonable job and lots cheaper than the motor trimmers quote of around $700 (from memory).
It's worth a try.
Disco
164189
Follow Up By: Axle - Saturday, Apr 01, 2006 at 09:36
Thanks Disco, Will have a look at that, the lining seems to stretch in them, bit of a pain.!
419111
Reply By: Peter - Saturday, Apr 01, 2006 at 03:15
Had the same problem with the Defender, got hold of a stapler and stapled the lining up. Not pretty, but effective. Sold the Defender with the roof lining still stapled and not a comment about it. May have even added a bit of character! (My girls thought so anyhow)
164192
Follow Up By: cokeaddict - Saturday, Apr 01, 2006 at 06:38
Struth Peter,
Promise me you will NEVER become a doctor.
419089
Reply By: foxtel - Saturday, Apr 01, 2006 at 19:48
Try this site, it the Aus Landrover owners site.
www.aulro.com/
164305
