1998 Hilux diesel 3 ltr - 5L engine Timing Belt light
Submitted: Sunday, Apr 02, 2006 at 15:31
Con_Qld
I have just replaced the timing belt but the timing belt light remains on. Has anyone had any experience with turning it off?
Any help will be very much appreciated
Many Thanks.
Reply By: Wisey (NSW) - Sunday, Apr 02, 2006 at 16:57
Con
near the trip meter button there should be a little rubber plug. remove plug and insert a wire to depress the "switch" and light should go off
Andy
164410
Reply By: 120scruiser (NSW) - Monday, Apr 03, 2006 at 08:06
Hi Con
If yours hasn't got the little bung in the dash to insert a rod for disarming the tb light you will have to remove the dash. In the back of the instrument cluster there will be two screw holes with one screw in one of them. Remove the screw and insert it in the other hole and this will reset the light until next interval.
Hope this helps
120scruiser
164514
Follow Up By: timber - Monday, Apr 03, 2006 at 08:15
Hope you can read this
419363
