A tricky one?
Submitted: Monday, Apr 03, 2006 at 17:29
PBob
A tricky one I think. When driving with my camper on the back, the electric brakes work
well. however, every so often, there is a small click noise coming from the brake sensor under the steering wheel, the
little red light clicks on with the noise (and off again) and the amber turning indicaters on the rear of the traier, blink on as
well. Any ideas?
Thanks.
Reply By: Notso - Monday, Apr 03, 2006 at 17:42
Vehicle electrics are a black art. Might be a short somewhere in the trailer wiring.
164591
Reply By: Member - Paul P (Bris) - Monday, Apr 03, 2006 at 17:43
Greetings
The controler model/brand is???? If its an early model Prodigy ( Tekonsha ) its the brake controller.
Paul
164592
Follow Up By: japmel - Monday, Apr 03, 2006 at 20:10
Sorry Paul I have to disagree with you, There has never been a problem with the Prodigy.
I think you are thinking of the Techonsha Voyager.
japmel
419521
Reply By: Derek from Affordable Batteries & Radiators - Monday, Apr 03, 2006 at 20:28
Don't blame the controller, it sounds like a short in the trailer wiring between the blinker circuit and the brake circuit. The click could be the flasher relay being activated by the brake circuit.
Open up the plugs and check for bad wiring.
Regards Derek.
164615
Reply By: Member - Ian H (NSW) - Monday, Apr 03, 2006 at 21:12
Check also the earthing of the lights on the c/t. That can do funny things.
164625
