jap adaptor diesel fuel filter
Submitted: Wednesday, Apr 19, 2006 at 17:29
ThreadID: 33047 Views:2449 Replies:5 FollowUps:2
Anybody had any experience with these filters. They screw into the nissan filter housing and have a water stop clear bowl at the bottom like the CAV filters. wondering if the filtration rate is okay for for 3.0 td diesel. thanks.
Reply By: RedGibber - Wednesday, Apr 19, 2006 at 19:47
Dublediff, I suspect you're referring to the thing that 4WD Systems flogs...if so, it IS a CAV filter (296 type) with aluminium machined adapters to fit various Jap vehicles in the existing filter heads.
Many folk use the filters...I've heard no bad reports.
AnswerID: 167880
Reply By: SteveL - Wednesday, Apr 19, 2006 at 21:17
These filters are made by Denco Diesel and if you contact them, I think you will find they do not recommend using these adaptors on the 3.0 td as the fuel system pressure is too high.-Steve
AnswerID: 167912
Follow Up By: dublediff - Wednesday, Apr 19, 2006 at 22:52
thanks for the tip Steve, I have emailed Denco and await their reply, I will pass it on if it is now any different. cheers.
FollowupID: 423188
Reply By: Michael ( Moss Vale NSW) - Wednesday, Apr 19, 2006 at 21:42
One problem is you cannot reconnect the idiot light to the new filter. Letting you know that there is water in the bowl, But you can pull the bonnet and check the glass bowl it it takes your fancy!!!
AnswerID: 167922
Reply By: Member - Roachie (SA) - Wednesday, Apr 19, 2006 at 21:45
I've got one and it works great. Like Michael says.....no idiot light on dash anymore, but filters are really cheap and can be changed often....I've been known to leave them for 20,000klm and still no problems.
Roachie
AnswerID: 167926
Reply By: dublediff - Thursday, Apr 20, 2006 at 13:33
Denco do not recommend their filters for vehicles with electronic type pumps....however Ber### diesel, Don Kyatt, etc all fit the jap adaptor (under various brand names) to the 3.0 td as well as the 100 series toys and 4.2 gu. Apparantely they have 5 micron filtration same as Nissan. Sooooo - I bought one??? Will let you all know how it goes. Thanks for all of your input. cheers dublediff.
AnswerID: 168058
Follow Up By: SteveL - Thursday, Apr 20, 2006 at 19:28
An alternative to buying the adaptor is to just buy the genuine CAV filter head.From memory it is a bit cheaper than the adaptor and easier to use.The only problem is you have to make your own bracket to mount it on ,as it is designed to be attached at right angles instead of flat like the original.-Steve
FollowupID: 423399
