Cruiser Question.....
Submitted: Monday, May 01, 2006 at 16:06
Bullwinkle
A mate of
mine just bought a '94 GXL petrol Cruiser. Does anybody know where the window washer bottle is located? We found the actual pump motor, but the hose goes into the firewall somewhere. Cheers......
Reply By: Member - David (WA) - Monday, May 01, 2006 at 16:23
It is usually located in the engine bay on the drivers side. The hose going into the firewall maybe the supply for the rear window.
David
170049
Follow Up By: Member - DickyBeach - Monday, May 01, 2006 at 18:49
I have a 94 Blue Marlin and my windscreen washer bottle is fixed to the firewall on the driver's LHS - holds probably 2 litres, hard to miss :).
425448
Reply By: VK3CAT - Monday, May 01, 2006 at 17:20
I think in my 94 model 80 series there was something in the left rear access panel with the spare wheel brace & bottle jack.
Cheers, Tony
170054
Reply By: phantom - Monday, May 01, 2006 at 17:27
Hi Bullwinkle,
I am sure that both front and rear washers are fed from the same bottle cos on
mine when i squirt it sprays both windows. I know it shouldn't but I must have a crossed wire somewhere.
170055
Follow Up By: hotdfa - Monday, May 01, 2006 at 21:10
its the seperator valve thats crook not expensive to replace........
425477
Reply By: FZJ 80 - Monday, May 01, 2006 at 17:59
Phantom.
Mine does the same. I think the fault may be in the switch
170063
Reply By: Hairy - Monday, May 01, 2006 at 19:20
Mine was between the air cleaner and grill on the drivers side but I moved it to make room for a spare battery.
170088
Reply By: Member - Matt M (ACT) - Monday, May 01, 2006 at 20:53
Ditto,
mine is a '94 GXL and the bottle is located front right in the engine bay. One bottle for both front and rear windows.
Matt.
170110
