gq oil pressure guage is dead
Submitted: Tuesday, May 02, 2006 at 00:31
ThreadID: 33439 Views:1840 Replies:3 FollowUps:1
hi guys,
did a search but didnt find much. my oil guage died while i was holidaying in tassy (with water crossings). if its the sensor is it fixable or where would i get a replacement, and how do i test the guage itself?
many thanks
gareth
Reply By: Member - MUZBRY VIC) - Tuesday, May 02, 2006 at 07:15
Gday
Nissan sell this item for about $120.00 ea................
AnswerID: 170168
Reply By: Shaker - Tuesday, May 02, 2006 at 09:26
Usually you can take the wire off the sender unit & earth it to the cylinder head, if the guage is working it will show full guage deflection, in that case it is the sender unit. If the guage still doesn't register then it's the guage itself.
AnswerID: 170183
Follow Up By: Shaker - Tuesday, May 02, 2006 at 11:12
Oh, for an edit function ..... my typo guage = gauge!
FollowupID: 425546
Reply By: Truckster (Vic) - Tuesday, May 02, 2006 at 14:59
Its common for the oil sender to die. its an easy fix, if yours has had the update, theres a breather on it that blocks.
AnswerID: 170229
