Coil spacers
Submitted: Monday, May 15, 2006 at 22:46
ThreadID: 33928 Views:2567 Replies:6 FollowUps:8
Thinking about fitting some 30 to 40 mm coil spacers to the Pootrol (2002)....can this be done with the poly air bags fitted ?
Reply By: Member - Roachie (SA) - Monday, May 15, 2006 at 22:55
Shouldn't be a problem at all. I have 5" Lovells springs (sits about 4" higher than standard; but I've got a lot of extra weight at the back) and I have Polyairs too.
I'm assuming you're keeping the OE springs?
I've thought about adding the spacers too.......AFAIK 30mm are the biggest you can buy?
Roachie
AnswerID: 172871
Reply By: Truckster (Vic) - Monday, May 15, 2006 at 23:08
What is the reason for it?
AnswerID: 172874
Follow Up By: govo - Monday, May 15, 2006 at 23:10
cheap and quick lift...don't really want to fork out for a complete lift kit...thought this way would be easier to do
FollowupID: 428565
Reply By: Muzzgit (WA) - Monday, May 15, 2006 at 23:54
New light/medium duty rear coils with approx 40mm lift should not cost you anymore than $150.00
AnswerID: 172881
Follow Up By: Muzzgit (WA) - Monday, May 15, 2006 at 23:55
Sorry, that should read $250.00
FollowupID: 428574
Follow Up By: Truckster (Vic) - Tuesday, May 16, 2006 at 11:51
I agree. Coil spacers are a bodge job.
FollowupID: 428610
Reply By: Redeye - Tuesday, May 16, 2006 at 06:53
I put 30mm spacers on my GU a couple of months ago. Give me a lift and I noted the vehicle was quiter with less road noise through the suspension. The original spacers were almost non existant.
Good value at $100 self installed.
Redeye
AnswerID: 172886
Reply By: P.G. (Tas) - Tuesday, May 16, 2006 at 07:24
Hey guys, don't forget to fit longer shocks with those spacers, nasty feeling hearing the shocks pulling apart or bottoming out.
AnswerID: 172888
Follow Up By: Member - andrew B (WA) - Tuesday, May 16, 2006 at 07:35
Was thinking about fitting these to mine. I figured the origional suspension will have sagged the 30 odd mm, so longer coils wouldn't be required. I could be a little misguided though
Andrew
FollowupID: 428585
Follow Up By: muzzimbidgie - Tuesday, May 16, 2006 at 11:47
PG. The GU already comes with long travel shocks. You would need to lift it a fair bit more than 50mm to get to the limit of the standard socks.
FollowupID: 428607
Follow Up By: P.G. (Tas) - Tuesday, May 16, 2006 at 13:06
G'day Muzz, I put King springs under my GU III (nominal 50mm) and found that with one side of the sway bar disconnected the shocks were at full extension. I replaced them with the appropriate Koni's and found another 2 inches of travel with no shock bottoming.
FollowupID: 428617
Follow Up By: muzzimbidgie - Tuesday, May 16, 2006 at 13:26
AH YES.....once you lift em AND disconnect the sway bar, well what can I say. That's a whole different ball game.
The original post said 30 to 40mm lift.
FollowupID: 428621
Reply By: Member - Charlie S (VIC) - Tuesday, May 16, 2006 at 15:26
You may need to look at extending the "bump stop" to ensure the spring doesn't bind.
AnswerID: 172953
Follow Up By: govo - Tuesday, May 16, 2006 at 16:04
now there is something l never thought of.....ty charlie
FollowupID: 428648
