Mapsourcece trip and waypoint problem
Submitted: Wednesday, May 17, 2006 at 13:02
madcow
Gidday folks, I have received a GPSMAP 60cx and am having trouble
loading up the trip and waypoint software into my pc. It seems to load
up ok but when I go to use it an error message pops up saying "there is
a problem with the mapsource registry. Please reinstall Mapsource and
start it again." This I have done along with rebooting each time and
with no success as the same message keeps appearing. I have also
unistalled it and reloaded with no luck either. Any suggestions/ideas ?
Dave
Reply By: Member - Reiner G (QLD) 4124 - Wednesday, May 17, 2006 at 19:17
I own a 60 CS and use it in my car and on the Guzzi........fantastic gear .
Do you need an unlock code for the waypoint software?
Garmin is allways painful until setup right but it works
well ones sorted.
Hang in there and contact Garmin if no luck.
Reiner
173190
Reply By: A.J - Wednesday, May 17, 2006 at 21:01
Was it a burnt copy??? If so you are more than likely missing some of the .dll files, happened to me when I tried to copy World Map.
Wetty
173218
Follow Up By: Gu_Patrol - Wednesday, May 17, 2006 at 21:38
he would have got the real Cd with his 60Cx.
I think ?
429067
Reply By: Gu_Patrol - Wednesday, May 17, 2006 at 21:36
Did you also install tracks4Australia. on your PC
173229
Reply By: madcow - Thursday, May 18, 2006 at 08:11
I reset the settings on my pc back to an earlier date, deleted the registry files, rebooted the pc. Reloaded the cd and hey presto all is ok. Why, I have no idea but thanks for the suggestions. I have loaded T4A into and it is a pretty good mapset. Next on the agenda is to put those numbers onto a map and work out where we are. That'l be fun and will keep the
grey matter occupied. I purchased the unit off ebay as it is not yet released here in oz yet and I believe the RRP will be around the $900 mark.
173294
